Karoq guide - engine advice and infotainment issues?
Hello!
This might be the first time I've ever ventured beyond the Octavia and Fabia sections of this forum... Anyway - my folks, both in their 60s, are looking for a second car. They want something similar sized to the Golf they currently have (and have had a long line of before that) but I'm encouraging them to look at other models, in particular SUVs, because they'll probably keep this a good few years now and I think the higher seating position will be easier as they get older (not that they struggle now, they're very active).
So anyway, they've seen a Karoq at a local garage, and quite like it, but they've done some research which seems to suggest that electrical issues with the infotainment system are quite common, but they were a bit vague.
So, I'm seeking your experience to try and understand a bit more!
  1. Are issues with the infotainment system common?
  2. If so, what are those 'issues' and are they expensive to resolve? Are we looking at a hardware swap or just a software reset/update?
Also, how does the 1.0TSI perform in a car this size? I'm not best placed to advise given my entire car history is 1.9 and 2.0TDIs. Is it comfortable both around town and on longer runs? They may occasionally use it to do trips to the other end of the country.
Any other buying advice would be much appreciated!
Problem is folks mention when they have issues, not when they don't. Our first Karoq, which we traded in for another new one in March, was bombproof for the 8 years plus we had it. We've had no issues with our new one, or with our nearly 4 year old Kamiq. Having said that the infotainment system does take a bit of perseverance to set up correctly, with numerous options. Our salesman for our new Karoq told us one option wasn't included on our car, but I found it was switched off in the menu system, just needed switching on!
Those that have the 1.0 TSI all seem to be happy enough with them. I bought the 1.5 simply because the difference in fuel consumption was so small. So it made sense to me to go for the more powerful option, given the size of the car.
How old is the car & is it a Skoda dealership? If it's outside the original three year warranty then I'd say buying from an approved dealer is essential. While I'm not aware of any specific infotainment issues, there are a number of others that really need to be covered. But that probably applies to most modern cars, given the complexity of the electronics & reliance on software combined, with manufacturer cost cutting. An example being LED lights which should easily outlast the life of the car. But Skoda have managed to produce LED indicators built into the headlight, that cost around £1k to replace.
My car was new in June 25 & in December, the speed limit detection stopped working properly. Here we are nine months later & they're still unable to fix it.
Edited by Rbz5416
Recently Browsing 2
