Superb 2021 noise
Hello,
I have a 2021 Škoda Superb Combi 4x4, 2.0 TDI DSG, 7-speed.
I would like to know what could be wrong, or whether this is normal.
At low speeds, usually in first or second gear, when I lift off the accelerator and then accelerate again, I can hear a knocking sound coming from the front of the car.
For example, when approaching a speed bump, I release the accelerator and then press it again, and I hear a knock from the front.
In other words, if I am driving on a flat road at around 20–30 km/h and repeatedly lift off and then apply the accelerator, I can hear a metallic knocking sound coming from the front.
It seems to me that the sound is more noticeable when I let the engine slow the car down and then accelerate again.
What could be causing this? Is this normal for this car, or could something be worn or faulty?
Not normal (and let’s face it, it’s a change that you’ve flagged so you’re on the right track).
My money’s on a lower arm bush split meaning as the weight moves forward under slowing down (you mention lifting off but not about braking…?) and then moving back under acceleration there is plenty around the bushes that can move enough to have metal strike metal.
Best bet is to get it to somewhere to get it up on a ramp and have a good look and wiggle around.
Thanx
No, no braking.
Is somehow posssible that can be brake pads? About three months i replace front brake pads with ABS brand.
And then about one week i have wierd noise when i drive foward and pres brake, there was one metal noise,and then when i go revers and pres brake there was again one metal noise. But after week that was good. (Brake pads moving i guess)
could be a worn cv joint/drive shaft thats clunking. Mine sounds similar and reckon theres play in joint/shaft so under aceleration you dont notice as its under pressure but if you slow down and accelerate again it clunks slightly. I assume the clunking is the slack being taken up. Doesnt do it full left/right but generally in a straight line.
Alasdair
Alasdair has a point - could also be the play in the driveshaft as you accelerate and engine-brake.
So i have been by car repair shop.
They did not find anything wrong.
They say thats normal for dq381 7 speed transmission…
I dont know…
Have someone here to test superb 2.0 tdi 147kw with dq381? Just drive stengt foward in 2,3 gear 15/40 kmh and releas the acelerating pedal completly for two secound and then pres it again. Is there a clunk nois somewhere front (radio off).
Can somebody here pleas test it for me?
Manny thanx
