2010 Skoda Superb electrical fault
Hi
I have a 2010 Skoda estate 2.0 auto. It developed a fault a year ago where the battery was draining overnight and after visits to 2 separate garages (costing £900), it was diagnosed as having a faulty drivers seat module/actuator. I finally found one and it was installed yesterday. Unfortunately, the power drain started straight away so its obvious the module was not at fault.
When the seat power wasn't connected, there was no power drain.
The garage, who are vw/audi/skoda speacialists say that it may require a further 8 hours of investigation costing another £640.
What could be causing the power drain? I am close to just selling the car for next to nothing as it is becoming a drain on my finances (excuse the pun)
Thanks for any advice
@GaryM1308 Check the switch assembly with the memory switches (1, 2, 3 and set). Due to its position a lot of dirt falls into it.
Simply unclip the assembly, disconnect it and measure the power draw without these switches.
I've fixed mine by completely disassembling, cleaning and reassembling it. (But I had slightly different symptoms, odd seat movement behavior).
Other possible suspect is the seat heating. Its controllers are positioned at the very lowest position of the car, in a recess in the bottom below the seats. If you ever had a bit of water in the interior, than these controllers are the first to catch that water and fail.
Edited by andrehj
Many thanks. I will get the garage to look into that. Strangely enough, the heated seat stopped working about a month before the power drain started
