2013 Superb 1.6 electrical issues
For a while while driving the engine would stall for a split second and the dashboard would show as if just had the ignition switched on, this was random and could be days or weeks before it happened again. This week while pulling up in a car park as soon as I stopped the engine cut out and the dashboard went blank, turning the ignition key did nothing, after about 30 - 40 seconds which seems an eternoty when you can't start the car the dash starts to flicker for a few seconds and then all is well and can start the car again and get on my way. Any ideas on the cause from you more knowledgeable guys on the cause? Car is a 2013 1.6 diesel Greenline hatchback.
Edited by Fekker
Udate, this issue has been traced to the wiring loom from the steering wheel, the column was in the lowest position and is causing an interruption in power to the dashboard kicking in the immobiliser circuit that momentarily cuts power to the engine causing a stall. With the steering wheel in the uppermost position the car runs perfectly. The job now is to have a look at the wiring loom for either a break in a cable, the loom catching when turning the steering wheel as while replacing the starter switch I may have caused the loom to be moved, or a loose plug. At least the car is now driveable again.
