A VW Group Global Recall 2026.
^^^ That is UK vehicles once a SAFETY CRITICAL RECALL is called in the UK, if one is called and VW Group UK do not get VOSA / DfT to believe there is no need for a recall as they will deal with the issue by a Service Campaign / Voluntary Recall. As they have managed to do several times over the past 2 decades. Maybe there are no Right Hand Drive VW Group or Skoda vehicles that might need inspecting. But nor Showing on the Gov UK web checker or even the Skoda UK one does not mean that latter a Registered keep might get a Call or a Letter, or VW Group UK make a CLEAR PRESS ANNOUNCEMENT in the UK that no UK Imported Vehicles are affected. Like they did in 2012 over DQ200,s by their favourite journal Auto Car. Then in 2014 a Service Campaign started after the WORLD WIDE / Global recall which excluded Europe had been running for 2 years.
Edited by Evolution13
  • Replies 63
  • Views 5.3k
  • That'll be my 2023 SEAT Ateca going in then. Sit down with a courtesy cuppa and a pastry for an hour and catch up on some reading and pay nothing and leave with some peace of mind it's sorted.
  • Warrior193
    Warrior193
    AFAIK, Galvanic action is possible whenever any less-noble metal is in contact with a more noble metal.
  • There seems to be a couple of other threads about this steering bolt issue, not surprisingly as a range of models are affected: I've just put my VIN (2018 Golf 7.5 GTI) into the main VW website as
there is no official or unofficial recall for skoda europe, only VW and Audi.
since there is no upgraded bolts, VAG will change bolst with same M12 x 1.5 x 70 mm number N105 524 02. no matter is it left or right sided wheel, bolts are same.
i found some pics.
On 09/10/2026 at 17:38, OccyVRS said:
From VWHub
No recall?
Not what I've seen!
1 hour ago, OccyVRS said:
No recall?
Not what I've seen!
By no recall what's being meant is no official SAFETY recall on the UK Government website.
It's telling that the VW Hub even uses the word "campaign", meaning they have (once again) apparently persuaded "the powers that be" that a safety issue is not a safety issue so can be handled as a Service Campaign or Voluntary Recall.
i found some pics.
The ADAC say different. October 2nd
https://www.adac.de/news/auto-rueckruf-vw-audi-lenkung/
You can check using your VIN here (I don't have a VIN for Skoda to check myself).
https://recall.skoda-auto.com/107/de-de
A) I meant in Europe (there is no recall in the UK as no RHD are affected, apparently) and B) as above, there are recalls in the EU.
16 minutes ago, imart143 said:
Nope. My car by VIN is not in any recall. How is it possible? More quality bolts used?
Your car is right hand drive.
He must have missed that the first time you posted it.
Huh? He's in Croatia. That's definitely LHD!
Wheel is on left side, correct, not UK.
Not all cars are involved. Some of them which have bolts of some series. VAG dont produce these bolts. Original bolts are made in some steelworks in India. Different factories, different versions, some of them were low quality. Same bolts are used on other parts of suspension, engine mounts, etc.
Edited by imart143
As far as I am aware, it depends on the generation of the steering system:
MQB_VWBS_GEN2 -----> affected (2WD?)
MQB_PP_APA ------------> affected (4x4 vehicles?)
EPS_MQB_ZFLS ----------> not affected (2WD?)
So, it looks like all the direct MQB generations are involved.
All three types are currently in use within my circle of family/acquaintances, which is how I know for certain which ones are affected and which are not.
However, this is purely my own speculation.y own speculation.
VW Caddy,s from 2013 involved in the Global recall that does not include right hand drive vehicles.
today I received a letter from VAG Croatia, regarding the replacement of one bolt of the steering rack. I won't go now because many rushed to the service stations and created crowds because they think their steering wheel will fall off. when the situation calms down, I will go. in our country, insurance companies supervise this service action and it is changed on literally every car on these platforms, because in the event of a collision, an accident or a bolt breaking, great damage and life-threatening damage can occur, so the action is not optional but mandatory. or your insurance will not pay compensation if they estimate that the bolt is to blame for anything. I translated it into Eng.
Edited by imart143
Recently Browsing 2
