Long charging cable
Die to distance from my home charger my regular cable is 12.5 metres long. Occasionally it will charge 5% and stop. Unplug, replug and get another 5%. With my regular yellow cable never any problem. Has anyone else had problems using other than the supplied Skoda cable.
2024 Superb PHEV.
Is this an extension cable you are using? If so, what gauge (mm2) are the cores?
Not an extension cable. A commercial EV charging cable from my type 2 home charger. 12.5Metres long.
Is it correct gauge (mm2) for the current used while charging?
Length of connecting cable can become an issue if its cross-section is too small, problem becomes worse in longer cables through increased volt drop.
Hi Warrior, the cable in use is 3 cores of 6mm and 2 cores of 0.5mm for the signals.
What is your cable a 7, 11 or 22 KW Type 2.? I have used my 20 meter 22 kW cable to charge PHEV,s from wall boxes or 11 kW AC 3 phase chargers.
What is the max. Amps output of a type 2 charger - 13A?
Standard wallbox chargers are 32 amp single phase as far as i know.
