Digital cockpit.
2025 Fabia Se edition 8inch touch screen, digital cockpit can you select speedo and rev counter side by side.
Regards
robsie
Regards
robsie
Does yours display the map in the middle?
Try the multi function steering wheel 'View' and use the thumbwheel to scroll and see what appears.
Hi lee01, viewing the vehicle tomorrow it has the 8.25 inch touch screen with digital cockpit i know if you have the 10 inch you can have a conventional speed rev counter layout, see what it's like tomorrow.
This link is to a set of Skoda Fabia Mk4 tutorial videos, including one for the "Virtual Cockpit" (VC)
https://www.skoda-auto.com/services/new-fabia-videos
The specific VC video is here
https://www.youtube.com/watch?v=I4-6j3XseEM
A traditional pair of circular dials (rpm and speed) is possible (example below) plus many other variations.
The Virtual Cockpit has a 10.25" dimension and a 2025 Fabia could have an 8" or 9" infotainment system (touchscreen). My understanding is that inbuilt 'navigation' is only available with the 9" touchscreen, but that should not prevent separate circular rpm and speed dials being displayed (as shown above) if the car has an 8" touchscreen.
My 2024 Fabia came with a hardcopy (paper) Owner's Manual booklet - about 150 pages - that includes 'essential' advice for a new owner. That information is copied into a much more comprehensive (and less handy!) online manual that can be accessed through this webpage.
https://www.skoda.co.uk/apps/manuals/Models
Edited by DerekU
This 2022 Fabia-related video may also be of interest as it shows a variety of different Virtual Cockpit displays.
Hi Derek.
Thanks for the videos and information really helpful. I test drove the car yesterday it has the Digital cockpit which displays speed as number's and a rev counter above in a line or circular around mph number which works well, i pick the car up monday.
Regards
robsie
Hi lee, no maps on screen, mph as numbers and a rev counter plus additional vehicle information you can select.
I was under the impression that, by 2025, all Skoda Fabia cars had, as standard, a 10.25" Virtual Cockpit. However, I now realise that the SE Edition model is the exception and its standard 'screen' specification is as stated below
Infotainment and Navigation
DAB - Digital radio reception
Wireless SmartLink for Apple CarPlay and Android Auto
8" Skoda Infotainment touchscreen display
8" Digital display
There's a video about the 8" digital display here
https://www.youtube.com/watch?v=z-REdqHbOqs
Although you will not be able to have the separate round rpm and speed dials display you were asking about and that's available with the 10.25" Virtual Cockpit, there's still quite a lot of flexibility.
The full digital 'look' is very tidy (image below) and what I used to use on my 2021 Hyundai i20 that had a similar type of instrument cluster.
Edited by DerekU
I can understand there being different sized centre displays as happens with many different cars but it's puzzling having different sized driver's displays. Can't see the point?
This February 2024 Skoda Storyboard
Škoda Storyboard
No image preview
Interior: Six Design Selections, sustainable materials an...
› Many packages, individual options and new Simply Clever features › Sustainable upholstery and door panel materials include recycled fabrics, …
states that for 'upgraded' Kamiq and Scala models a 8" Digital Display became standard, with a 10" Virtual Cockpit a an option.
8-inch Digital Display as standard, customisable Virtual Cockpit as an option
The upgraded Scala and Kamiq come with an 8-inch Digital Display as standard on all models. The optional, customisable Virtual Cockpit offers a 10-inch display.
As I said above, UK-marketed Fabias now have a 10.25" Virtual Cockpit as standard EXCEPT for the 'entry-level' SE Edition model that has the 8" Digital Display.
The trim levels of current-model UK-specification Fabias are summarised here:
https://www.motorpoint.co.uk/model-guides/skoda-fabia-models-and-trim-levels-explained
The online Owner's Manual for my late-2023-built Fabia SE L has an issue-date of 19.6.2023 and contains no mention of a "Digital Display", whereas the "Driver information system" section in the next Owners Manual chronologically (issue date 15.1.2024) has two sub-sections - one for a "Digital screen" (ie. the 8" Digital Display) and another for the Virtual Cockpit (ie. the 10.25" instrument-cluster screen).
Personally, I'd be perfectly happy with the capabilities of the 8" Digital Display. Although my Fabia has a the big (9") infotainment screen with 'navigation', I've no wish to display mapping in the instrument-cluster - a feature that's only possible with the Virtual Cockpit. But, as I also don't wish to pair a phone with my car, nor play music within it, nor have the radio on, I'm probably not a typical mid-2020s car owner.
8" Digital display
Hi Derek.
This is the display i have (digital cockpit) also no hill start assist with this model.
Currently there are five UK-marketed Fabia Mk4 models
SE Edition
Design Edition
SE L Edition
Monte Carlo Edition
130
and (assuming Skoda's data on the online Standard Equipment data are correct) SE Edition and Design Edition models do NOT have the "Hill Hold Control" (HHC) driver assistance feature, whereas SE L Edition, Monte Carlo Edition and 130 models do have it.
HHC is mentioned in the Driver Assist systems/Braking and stabilising systems/Overview section of my late-2023-built Fabia SE L model's online Owner's Manual (and in later Fabia Mk4 Manuals)
Hill Hold Control (HHC)
The HHC system helps with hill starts by braking the vehicle for approximately 2 seconds after the brake pedal is released.
Operating conditions
  • The gradient is at least 5 %.
  • The driver's door is closed.
I don't know if my car actually has the HHC assist feature and - as my Fabia has DSG transmission and my two working feet can simultaneously operate its two foot-pedals - I've no real need for HHC. My last motorhome (Fiat-Ducato-based, left-hand-drive, 3500kg weight with manual transmission and a handbrake designed for people with a long left am and gorilla muscles) had a hill-hold system and that was really helpful starting from rest on a steep hill.
There is some discussion on the OBDeleven forum about activating HHC on Fabia Mk4 cars that do not have HHC as part of its standard specification. I don't know if it can be done on your 2025 car, but you could explore that possibility if you really like the idea of having HHC.
Hi Derek.
Thanks for the information HHC is a really good feature with a manual gearbox i will look into having HHC activated if possible.
Edited by robsie
Recently Browsing 1
