Felicia's have blower motor relays?
Hi guys,
When adjusting my blower motor speed I only have 2 out of the 3 blower speeds, when I turn the dial what I get is at: -
0, the blowers off
1, what seems to be speed 2
2, speed 2
3, speed 3
So it’s not drastic but I would like to have speed 1 just blowing lightly. Do I need to replace a resistor (is there one?) if so where is it and which one if not is it a motor or switch issue?
Regards Rob
It's 1.9D, right?
Those use different heating from Favorit, so I'm not familiar with it. But you should be able to locate the resistor pack in the engine bay, following wires from the motor.
There are two bimetal contacts that appear to short the resistors if they overheat. It's possible that the one for 1st speed got stuck.
1658_odpor-topeni-predradny-favorit.jpg?
Recently Browsing 1
