Skoda Karoq 2026, 1.5 tsi, petrol - First oil change when?
I have just bought a brand new Skoda Karoq, 1.5 TSI, petrol and I was wondering when should I do the first oil and oil filter change for longlevity of engine (vw508, 0w-20)?
I own a Skoda Fabia, 1.0 TSI, petrol from 2018 and I did the oil and oil filter change firstly at 5 000km and then every 8 000km (vw 504, 5w-30) and car is now at 92 000km without any issue.
Depends on your mileage, type of runs and what makes you happy.
I’m guessing you plan to keep the car for many years, so make sure the service interval is set to Fixed so oil and filter changes are every 12 months or 10,000 miles. Nothing to stop you doing oil and filter changes more often though. I bought my 2023 Karoq (in April 2024) with 1,080 miles recorded, selling dealer included an oil and filter service as part of the presales prep. When I bought our 2015 Fabia in 2016 900 recorded miles and 1 year old, from a car supermarket so no pre sales prep, I had my local independent do and oil and filter change immediately. Karoq does around 7000 miles a year and the Fabia around 2000 miles a year both have annual services though.
Its brand new car, just bought it. The goal is to keep it as long as possible, same to the 2018 Fabia.
I use it mostly for driving to work only 30km motorway driving and 1-2 long trips per year (more than 500km motorway), I use the other Fabia for rest. I was thinking to do the first one in 5000km and then every 8000km (or 12 months if a year the car does not reach the 8000km), exactly same pattern to my 2018 Fabia.
That's a good strategy, so the first oil/oil filter change in sub 1100 miles (1800km) on both of your cars, and then 7000miles (11 000km) or 12 months, whichever comes first!
Edited by AlexNk
I change mine twice a year and only change the filter on the third change because taking that under cover off on the drive is a tricky job if not on a ramp. I use a vacuum pump for oil changes when not changing the oil filter It's so easy.
Good strategy with twice per year, close to mine because I usually drive 8000km less than 12 months so it is actually twice to change within 12 months! I do the traditional method and filter change always because mine is located in easy spot in both cars.
me too . i buyed 20 litres of Shell helix ultra 0w30 AV-L for good price and changing oil with filter on 9000 kms - 12 months, and between that i change only oil in half that period.
right, I do the same when 20 liter dunks are on big sale! Is it any benefit not to change the oil filter all the time? I always those two are like twins. You change them both if one changes
everything is better than factory 30000kms change. my oil is always light brown, no matter what. nothing to clog filter.
Edited by imart143
You are using VW 504 and not VW 508 (0w-20)? Mine 2026 Karoq 1.5 TSI, DXDB, petrol only recommends VW 508 so I was thinking not to change it.
My other car, Skoda Fabia 1.0 TSI, CHZC, petrol, 2018, came initially with VW 504 so I just keep changing to that oil.
Edited by AlexNk
yes, i am using 0W30 VW 504/507 oil.
It was VW 504 originally in the car since you bought it, right? No changes later.
Edited by AlexNk
Simples. The Brand New TSI,s recommended oil is VW508 00 / 509 00. 0w 20 FS IV. If you want to ignore and use VW504 00 / 507 00 so 0w 30 FS III, or 5w 30 FS III then it is your car to use that for Fixed or Variable Servicing or sooner than annual. Even 5 w Full Synthetic can be used for Fixed Servicing of Oil & Filter changes. It is just that is not what VW Recommended as they changed oil spec to get WLTP & RDE2 certification.
It was VW 508/509 0W20 originally in the car, changed only on 32000 kms and 66000 kms. i bought it with 82000 kms and change oil and filters same day. in my skoda service manual it says oil can be 0w20, 0w30, or even 5w30, depends on climate, only notice is: with thicker oil, emissions can be higher and fuel consumption too. I put 0W30 because its 50% cheaper and i like to change everything by myself, not just oil. so i bought 5x5 liters to have in next 3 years change 2x a year, it is my hobby, car is my pet 🙂 have a vacuum pump also.
32 000km interval is just insane!
I will follow the 8 000km to my new Karoq 1.5 TSI also (I will do the first one at 5 000km). Since it is in warranty I will keep the VW 508 for the four oil changes in the first three years and then I will rethink for the VW 504 later.
Edited by AlexNk
Even if 5w 40 FS VW 502 00 non long life oil of the correct saps was more expensive than VW,s recommended Long Life oil be it VW504 00 507 00 or 508 00 / 509 i would use the 5w 40 FS in a TSI pre or post 2018 & do oil changes at 10,000 miles 12 months or sooner. I run cars and get the fuel consumption and emissions i get, i do not run a car on a Rolling Road indoor as VW Group do for the old tests and the new one. In the old regime they run TDI,s with diesel in the engine oil. Well VW / Audi / SEAT did at times.
Edited by Evolution13
I am tempted to use VW 504 when my brand new Karoq (sept 2026 manufactured) reaches 5000km, as I have 16L left in the dunk from my last Fabia change (I buy dunks of 20L VW 504 for changing to Fabia every 8000km). My worry is that there is void guarantee risk since if something happens to the car they may be for sure a process to check that does not have VW 508 oil in? The oil filter will replace exactly the original one.
Edited by AlexNk
Never had a new car but friends have. A few dealers like mitsubishi etc change oil and filter at around 1000-2500 miles on brand new cars then revert to standard service intervals. Not sure about Skoda. Something to do with a run in period to remove any debris etc from new engine .
Alasdair
^^^ Exactly. Even with Skoda dealerships, some used to give you a FREE Change of oil. or a voucher to come in after 1,000 miles and have an Oil & Filter change and an inspection. I have not seen any doing that since about 2012 when SERVICE BOOKS stopped being put in the car at Hand Over. People might well want to change oil in cars earlier than annually, but as the first oil change. That is good oil filled at the factory. It has a job to do and IMO best leave it doing that job. Check the oil regularly though. From getting the new car home. Know where the oil is at Stone cold and compare to where when checked as per the Manufacturers guidelines/ @ Normal Operating temperature after a few minutes parked on the flat.
do a service manual on 30000 and 60000 kms, and in between do just oil change by yourself. use a vacum pump and suck from dipstick hose. dont touch sump plug. service wont investigate which oil is in engine.
