Suspension saga continues
Can someone advise or help?
Suspension question - got my 034 Motorsport dynamic droplinks fitted by ,, mechanic,, who fitted them upside down...i know don't ask.
Yesterday I've spent good three hours re-fitting them and adjusting them. Both sides equal. Car back on solid even ground to take pre-load off the sway bar. Took the car for test drive all goid, felt really tight, responsive steering so all good.
Parked the car up and noticed driver's side is sitting lower than passenger side 🤔by maybe half inch. Anyway it was quite late so left it ready to start all over again but it seem to have settled. Its still lower but maybe half of what it was.
Is it likely to settle further or am I better of adjusting myself?
Weird.
U sure it wasn't like that before the endlinks were fitted?
I didn't have any change in suspension height when I fitted my Whiteline frontend links.
3 hours ago, JR RS said:
Weird.
I've never noticed it and i do stare at my car a lot 🙈😀
It has settled by quite a bit so maybe it does need some time but I've never seen anything like it before 🤔
Haven't noticed on mine either - have you got adjustable rideheight?
No mate, non DCC standard suspension... pretty much whole suspension has been replaced
@MarioVrs They're Bilsteins on there - B6? Has it settled any more?
I know if they're not equally adjusted they will put torsional forces on the arb but I don't think they would have enough to lift a corner.
Also, I had to relook at mine, I don't think Racingline ones are top/bottom; seem entirely reversible so possibly the mechanic just didn't think there'd be that factor? I see the 034 ones come in bits to put together though. RL ones are already made and you just rotate the main middle bar to extend or retract both when car is down on the floor etc.
