Dampers too shorts? - Octavia Scout MK2
Hi all,
Since I bought my mk2 Octavia Scout, I have a gigantic clunk when the dampers are decompressing.
It happens in all 4 wheels independently.
I've replaced everything in the suspensions (Strut mounts, ARB bushings, ARB rods, and dampers).
I've replaced the shocks absorber with the Bilstein 22-183729.
They are advised on ETKA for the vehicles with the "Heavy Duty Suspension" and the PR codes UB2, G07, L66, which are mine (see picture).
And the problem is still the exact same!
I came to the conclusion that the shocks are too short for the Scout version I own and they are topping out when I go down a speed bump, a pothole or whatever.
When I look at the characteristics of the dampers, the extended lenght of all available versions is the same: 552mm. For both heavy duty and regular suspension, including the Bilstein I've installed.
But the Scout version of the car is supposed to be sitting higher...
- So is there actually a difference in lenght in Scout and Regular Octavia's dampers?
- If yes, what's the actual reference of them?
- If no, where could my issue come from?
I'm now 4 years and too much € deep into this, I need to find a solution...
Thanks heaps y'all for your help!
Edited by Veacky
pictures layout
Are the paint identification markers still visible on them?
Bump stops replaced as well?
You mean on the shocks?
If yes, yes it is. I've replaced them 2 months ago...
It's written "BILSTEIN / 22-183729" on them.
If you mean on the Coil Springs, it's 2 pink paint marks.
They look perfectly fine.
No new bump stops yet. But they are there for when you bottom out anyway, no?
Edited by Veacky
On autodoc, 1T0413031FK isn't listed against the Bilstein 22-183729 front shock absorber but 1T0413031HL is listed against Bilstein 22-183729.
Sachs and KYB list 1T0413031FK and 1T0413031HL against the same aftermarket shock absorber, so these two shock absorbers do appear to be interchangeable.
Bilstein lists the 22-183729 front shock absorber against both standard ride height and increased ride height OEM part numbers.
It may be just an oversight on Bilstein's part that they haven't listed 1T0413031FK against their 22-183729.
OEM part number for front shock absorbers (Octavia MK2 estate 4x4 with increased ride height) (55mm strut diameter)
1T0413031FK (up to the 2008 model year)
1T0413031HL (from the 2009 model year)
Edited by Carlston
