Fabia 2024 SE comfort mpi fault
Hi I already posted on this subject.
I'm being treated as though I don't know anything by the dealer, not a Skoda dealer because my car was a trade in....
So mine has the intermittent fault causing loss of power then temporary limp mode. I got the car in June and it has happened 3 times since and I lost confidence in the car, it is not just a nuisance it's dangerous!
The power just disappears when you are at a junction where you have to cross oncoming cars....then you have to deal with limp mode! Seems that some think that
when you turn off the ignition and the fault disappears that's fine. I do not! It's the fact that you are vulnerable due to the fact is that it can occur anytime....not a good thought when you are doing 50/70mph!
The car is with the dealer now, the service manager inferred that my driving could be at fault and causing it!
I still have a little hope that this will be resolved....if they can't fix it , by law I am entitled to a replacement....which I guess is the best outcome. However I wanted the car I bought...
Best stop waffling.
I've already heard from a few others with their experiences but I would appreciate some more.
Thanks 👍🏻
No image preview
Legal Rights
Up to 6 months is an important time period after buying!!!
@Sklinda
This link is to the earlier forum topic that discussed your Fabia's problem.
https://www.briskoda.net/forums/topic/541431-any-luck-with-intermittent-limp-mode-fault/#comment-6031427
and this link is to the Motor Ombudsman website's guidance on the 2015 Consumer Rights Act.
https://www.themotorombudsman.org/knowledge/what-is-the-consumer-rights-act/
You seem to be under the impression that the type of fault your car is experiencing - sudden loss of power and (as I understand it) the fault clearing if the car's ignition is switched off and the vehicle restarted - is commonplace with Skoda Fabia Mk4 cars and that Skoda is well aware of this.
Many thousand's of Fabia Mk4 cars will have been sold and - while there's little doubt that some of these may have gone into 'limp-mode' - there's nothing to suggest that this is a known and widespread problem with Fabia Mk4 models. Most (all?) modern cars have a built-in limp-mode capability - it's a protective anti-damage feature. But there is no single reason for them doing this, nor any single well-publicised fix.
In the earlier topic @bazz2004 referred to the issue he had with his 2023 Fabia. But his car is older than yours, has a different engine and, when the problem occurred, fault codes were found (which you were told was not the case with your Fabia).
Your car is still within the Skoda UK 3-year warranty period and any free-of-charge repair work within the terms and conditions of that warranty will need to be carried out by a Skoda dealership.
@bazz2004 said that his car's problem was finally addressed successfully by installing a necessary software update, but, as you bought your car from a non-Skoda dealership and the fault is being investigated by them, if a Skoda software update were required, it's unlikely that 'your' dealership could install this.
If there are indeed no recorded fault codes and your car is currently running perfectly, it's going to be extremely difficult for your dealership to accurately diagnose why it has suddenly lost power temporarily on three occasions.
If your dealership cannot assure you that they found the cause of the power-losses and are confident that they have cured the fault, you may want to try insisting that they take the car to a Skoda dealership and ask that dealership to investigate further. Otherwise, you may have to fall back on the Consumer Rights Act.
(If you think you may have to go legally head-to-head with your dealership, you should keep a record of discussions with the dealership and email them about what's been said and done.)
Edited by DerekU
Thank you DerekU,
I have seen lots online with the same problem but not always the same year, but Fabia mk 1, 2,3's.
I have had advice from the CAB and used it to send a letter outlining the problem and detail about the 'incidents'.
I paid £13k for the car and I'm not going to keep it with the fault. I've had the car for 4 months! Under the consumer rights 2015, which are there to protect their rights, and do state that if a repair can not be done then you are entitled to a replacement. If the dealer will not then I will take it back to CAB to level 3.
I am loathe to use the ombudsman just yet as you have accept the result, that's it the end. But if all else fails I will use it.
Yes I understand that they are saying that it can't be fixed, but I think they could do it just don't want to, a common behaviour it appears.
The car has been to the Skoda dealership service centre the 1st time and I assume EMG are using this time.
Unfortunately, there is little chance of you getting any resolution from a dealership - or Skoda themselves.  The service department will run diagnostics which will pick up no faults and their excuse will be something along the lines of – there’s nothing showing as a fault so there’s nothing to fix.  You have a low battery level showing on our equipment that may be causing your issues.  Or, because you are making too many short journeys the car will have issues.
I bought a start-stop CTEK charger and later replaced the battery with a top of the range AGM model.  The frequent software and electronic glitches continued and finally another frightening limp mode breakdown. So, I spent a fair amount of money following “expert” advice from Johnson’s Skoda Wolverhampton and got nowhere apart from some pretty confrontational meetings with successive service managers who didn’t stay for very long.  I’m pleased that I spent none of this extra money at the dealership.
It was a mistake to replace a very old car with a model full of over complicated and glitchy electronics.  We live and learn.  I’d suggest getting rid of the Fabia in favour of an older low mileage car with basic tech which works.  There are loads of cars in our neighbourhood that are about 10 years old and look in pristine condition.  Manufacturers used to plug reliability and build quality but cars are no longer built to last.  It’s three-year warranties to go with 3-year payment plans.  After three years you are expected to “buy” a new car.  Effectively it’s never-ending HP for a disposable vehicle.
The alternative is to do battle with the dealer and Skoda which will be an exhausting process.  The last couple of years were hell for us because the Fabia could have easily let us down in a tricky traffic situation.  The size, speed and volume of HGVs on today’s roads is hard to believe.  There’s much to be said for getting a car about 10 years old which isn’t riddled with twitchy electronics and software so long as it has a dry timing belt. Skoda did get that bit right with the Fabia.
We did get a software update on the drive from an AA silver service technician following the last limp mode episode. So far, the limp mode issue hasn’t recurred.  The update fixed an issue with the throttle body assembly and became available mid-2024.  It seems that even Skoda trained staff, when servicing cars, fail to check that such updates are available and have been applied. Maybe they just don’t know what’s going on at Skoda or what updates are available for particular models. Our car still does things like changing the digital dash layout at random and giving nonsense guidance for changing gear at particular speeds.
It’s hard to know how to proceed  but doing nothing isn’t an acceptable option. If they can't fix the issue perhaps insist that the dealer changes the car. Nobody should have to drive a car that they believe has a potentialy lethal fault. Good luck.
Hi bazz2004
Thanks for the advice.
I had been down the proper legal channels but because there is no solid physical evidence of the fault it's just my word, and I am just a woman!
So they had my car in for a few days, gave me a courtesy car, and drove mine around for a couple of hundred of miles and eventually said they thought I was catching the speed limiter switch when flicking the indicator which was on 20mph and gave the same kind of feeling I described during limp mode......I had an awakening.....what am I doing trying to fight this big cooperation with no power behind me except advice from cab over the phone. I'd had enough I took the courtesy car back, was told if I have any more trouble to go back , I took my car and nothing has happened to the fabia in the 2 weeks since.
I could not stand the pressure of it any longer, just not worth the stress....and that's exactly what they hope to happen!
You are correct that taking on Skoda and a dealership is too stressful but don’t sell yourself short.  I do think that the forum is of little help for such situations. The car is not safe for you and it’s not your fault.  I suspect that for someone who commutes longer distances and lives in an area with free moving traffic the limp mode issue may never surface. Anybody who has experienced limp mode in heavy traffic would not downplay the seriousness of the matter. There's a lack of empathy by some on here.
I live close to a major motorway junction and the motorway is frequently gridlocked. There is heavy traffic almost everywhere.  The school run is horrendous and the roads are constantly subject to temporary traffic lights so potholes and small sections can be repaired.  The Fabia 4 could achieve 40mph if I averaged over 16mph on a short run. In practice that rarely happens and not because I’m choosing to crawl along in low gears.  I would move faster on an electric scooter.
A few weeks without the limp mode issue is not grounds for thinking all is well. We are still very uncomfortable driving our Fabia despite the last such breakdown being months ago. We so hope that the software update has removed the problem. Realistically, nobody connected with Skoda is interested. I'd go further and say that our local dealership doesn't understand much about their cars. Sales staff are far more competent than the service dept.
The question is what to replace your car with.  Not easy to decide but I am sure that cars are no longer built well or with reliability in mind. They are too complicated. I’d keep well away from cars in the VAG group which includes Skoda.  Maybe something like the Honda Jazz with a petrol engine is worth a look? Honda no longer produce the petrol version of the Jazz which now has a hybrid power train.  The Jazz doesn’t come in 57 varieties like the cars in the VAG lineup. It's basically just one Jazz. Any issues will have been identified and sorted by Honda - unlike with Skoda.
Thank you that is very interesting to hear!
I hate to appear defeatist, but I have a health condition and after the battle ensued, and continued for a few weeks I had a horrible flare up. I have to put my health before a car V dealer battle, but at the same time I have no protection if the limp mode happens again. The dealer said please don't hesitate to come back if you have any more trouble..... however I have no faith that they would be willing to try properly to find an answer. It would need to be before march when the manufacturer guarantee expires.
'Limp Mode' began to be introduced on cars in the 1990s, so it would necessary to go a long way back to find a vehicle without it.
Besides my 2023-built Skoda Fabia that has automatic transmission and a turbocharged motor, I own a 2009 Skoda Roomster with manual transmission and a normally-aspirated motor. The standard specification of the Fabia includes a lot more 'kit' than the Roomster's, so, logically, the Fabia has a lot more to go wrong. My Fabia has a 'limp mode' feature, but so does the Roomster (as mentioned in this 2017 forum topic)
https://www.briskoda.net/forums/topic/441876-limp-mode-on-roomster3/
The Honda Jazz has an enviable reputation for reliability, but that doesn't mean earlier versions are 'simple' or that problems with them are easily/cheaply diagnosed and cured, as this 2022 clubjazz.org forum topic proves.
https://clubjazz.org/forum/index.php?topic=14521.0
Any doctor will tell you that obtaining from a patient sufficient background information to allow a reliable diagnosis to be achieved can be extremely difficult. In bazz2004's Fabia's case, the car was producing DTCs (Diagnostic Trouble Codes) and these needed to be cleared to allow the car to run properly. But, in Slinda's Fabia's case, the car has just suddenly lost power (Did any dashboard lights illuminate when that happened?) and, after the car was restarted, it recovered and no DTCs were subsequently found.
In the 1980s one of my VW Golf GTi cars developed a starting problem in very cold weather. The vehicle was within its 1-year warranty period, so the VW dealership had it for a week, I was given a courtesy car, and parts were replaced. When I collected it, the workshop-manager said "It's still doing it, you know it's not right, I know it's not right and VW know it's not right, but it always starts within 30 seconds and VW says that's 'acceptable'" I didn't like it, but they had done their best.
It seems to me that slinda's dealership is doing its best to help, but, as there are no symptoms to explain why the car had lost power and then self-corrected, it's not easy to see what more they will be able to do unless the fault worsens.
Hi thanks Derek,
Yes I understand that a lot of cars have limp mode, my old Peugeot did, it went into limp mode when there was a fault with the engine management system.
That's the confusing thing about it, the engine light does not come on the dash.
I know a little about old cars lol but not new, this
One doesn't have a carburettor but some air thing! 😊
Now it seems that if its not detected by computer diagnostics it doesn't exist. I know how the accelerator felt under my foot before during and after the fault. I have experienced limp mode and it's a horrible feeling. And it was unnerving and didn't give me confidence .
Now the dealership has said they think it's the slider switch on the indicator stick, which I may have inadvertently switched on and off , the speed limiter...but there's no way my small hands could do that when using the indicator, I have tried.
That’s correct. The fuel/air mixture is controlled by electronic sensors and cables have been replaced by wiring. What could go wrong?  There’s not much more than anybody can say but I’m enclosing two pictures concerning the fault on our 2023 Fabia mc.  One is a photo of the screen in the yellow AA van before the technician cleared the fault and all record of it from the car’s onboard computer.  That makes the car driveable again, seemingly without issue, but the fault recurs and nearly all power is once again lost.  The second is a box from the job sheet left with us after the silver service AA van technician updated the software at our house. He said that this would not be a problem in future and it’s over 8 months since the last limp mode crisis.  Fingers still crossed.  The car is in for a full service and it’s first MOT but not with a Skoda dealership.
@Sklinda
I think the garage probably does not believe that - on the three occasions when your car lost power - it was because you had engaged its speed-limiter by accidentally moving the switch on the indicator-stalk. (Out of curiosity I tried moving the switch on my own Fabia's indicator-stalk to see if that theory had credibility, but it seemed very unlikely.) It's just that the garage cannot replicate what you've told them has happened and they are clutching at straws.
It might be worth you asking the garage to demonstrate to you (by driving your car with you in the passenger seat) what the effect of engaging the speed-limiter is and then you will be able to confirm that it's nothing like what you've been complaining about.
Edited by DerekU
There does seem to be always something else to a thread as I'm discovering.
My suspicion has been that the turbo version ,at least, doesn't take kindly to lots of very short runs. After our service the wife drove to the dentist which isn't far as a crow flies but is always a slow crawl in practice. When she got back she mentioned that the crazy tips as to which gear to choose were back. A longish run has fixed it but getting over 50mph is getting harder and harder with ever increasing traffic congestion.
I've just come across an assessment of the Fabia 4 TSI saying that for drivers doing lots of short journeys and wanting an automatic gearchange the cars are not recommended. Ours is a manual version but journeys are nearly all very short in congested road conditions. I've tried to attach the body of the article and have given the link too, but I'm not great with posting stuff..
Hopefully, reputable sellers of the Fabi mk 4 will assess whether the Fabia 4 is a suitable purchase by asking the customer about their driving needs..
Skoda Fabia Mk4 1.docx
Thanks that's great, the source is Carchecker pro?
Yes, sorry the attachment isn't there. Link is :
https://www.carchecker.pro/reports/skoda_fabia_mk4_1.0_tsi.html
I'll see if I can post the body of the article again.
It's a long running nightmare with with our Fabia 4 mc. You just know that the dealers think older customers must be mentally challenged when they continually raise issues that they can't identify with their equipment. At least the article provides some expert evidence. Maybe, even persuade the dealer into helping you out of your pedicament but I wouldn't hold your breath on that one. Hopefully your model comes into this particular category. VAG group and Skoda are in big financial difficulties now. Chinese cars are building their share of the market very quickly.
Thanks Bazz that's very useful and very kind!
It anyone wants or needs a small capacity petrol automatic and it is going to be less than 8 years old then a 1.0 tsi with a dq200 DSG is no more likely to have issues than any other manufacturers small petrol autos including cvts with engines with a gpf. Thankfully since 2018 the DQ200 DSG issues are much reduced, especially when matted to a 1.0 TSI rather than to a 1.5 tsi act.
Thanks, I'm sure that is the case but I have been unlucky to buy a car in june that does have the dsg problem, intermittently
I do acknowledge that some of the problem is due to short journeys and sitting in traffic. However I live in a village close to Cambridge, a densely populated city. I do go into Cambridge when necessary and also drive to the other end of the village, to other places 3-5 miles away. It does get longer journeys regularly where I drive at 50, 60, 70 mph!
Correct me if I'm wrong but I thought new cars are built for any length or type of journey......
@Sklinda What is the intermittent issue with the DSG that is not just the issue with the engine? Yours being an MPI so no turbo should be idea for short cold start trips?
Edited by Evolution13
The title of this topic is "Fabia 2024 SE comfort mpi fault".
That UK specification Fabia model had a 80PS MPI (Multi Point Injection) motor and (as Evolution13 has observed) this was normally-aspirated (ie. NOT TURBOCHARGED). The gearbox was 5-speed manual and a DSG automatic transmission was not an option.
The summary on the carchecker.pro link reads as follows
Reliable supermini with well-documented, manageable issues
The Skoda Fabia Mk4 with 1.0 TSI is one of the most dependable small cars on the market. The EA211 EVO engine is a proven unit used across the entire Volkswagen Group, and most reported issues are moderate in cost and severity. The key concerns are turbo actuator sticking from gentle driving, carbon buildup from direct injection, and GPF clogging on short-trip cars. Manual gearbox versions are significantly more reliable than DSG automatics. With regular longer drives and standard maintenance, most owners report uneventful ownership.
But @Sklinda's car does not have a TSI motor, nor a DSG automatic transmission.
My own 2024 Fabia SE L does have a 1.0litre TSI motor and DSG transmission, so the carchecker.pro comments would be relevant to it - but they are really not relevant to @Sklinda's car and just muddy the issue. Her car is as 'simple' as a Fabia Mk4 can get and (as @Evolution13 has said) should be very suited to a motoring life involving lots of short city journeys.
So @Sklinda Is your Fabia a 1.0 MPI engine car with a 7 speed Dry Clutch DSG?
Recently Browsing 1
