2014 Superb Lauren +Klement estate drivers footwell water ingress, again!!
Having had the sunroof drain thoroughly cleaned / checked a few months back and with rain in between, I`d had no water in the drivers footwell for months..Yesterday after the deluge overnight, got in car to find a massive puddle on the rubber mat. I`m going to investigate behind the scuttle panel under the wiper arms, but wondered what I would actually be looking for and where once the panel is out? I`ve also seen it suggested about issues behind the wheel arch trim and again, wondered what I would be looking for once the trim is out?
Edited by scubasad
Not sure on the superb but I had water in my old octavia. Combination of damaged/flatend door seal and also coming in behind door card.
Alasdair
This is dripping down under the dashboard above the throttle pedal. I have a bowl perched there at the minute which was half full when I checked this morning.. I`ts extremely annoying as I have no idea where it may be coming in from. Tried to remove wiper blades this morning to get to the scuttle panel but cannot get the wiper arms to part company from the bolts and don`t want to risk breaking the windscreen so looks like I`m going to have to get garage assistance..
The way it's been raining, I'd suspect it's just the scuttle not draining the water out as fast as it's been coming in. The rough way of looking is pour half a bucket of water down that side of the scuttle and see if it comes out inside the car, or just at the bottom of the wing behind the wheel.
I'm not particularly familiar with the Superb, but on the Octavia (and a lot of modern VAG cars), you can unbolt the panel at the front of the scuttle for access rather than strip the wipers off. If it helps you see how it goes together, the panel is often painted black as opposed to body colour.
Normally on VAG cars, there's a drain hole at each end of the scuttle to channel water down the inside of the wing. It's normally oval and about big enough to get your thumb stuck in.
If you do want to take the wipers off, you can get puller tools. Mine's a Sealey VS806, but you can get similar ones in no-name. Give the spindles a good spray the night before and they should come off fairly easily with the right tool.
If you're taking the arch liner out, just have a good look for a built up of road grime/dried mud, give it a sweep out and have a look corrosion hidden by the build up. Superb's don't normally rust though, so I'd go in fairly confident that it's nothing bad.
Edited by StevesTruck
Recently Browsing 1
