No GPS Reception
Hi, new here, so here goes…
I recently purchased a Škoda Octavia Mk3 vRS Combi, and mostly, all seemed ok.
However, the dash display is now showing an intermittent 'No GPS Reception' notification, which causes the number of satellites to drop in/out, and although it's showing long/lat, sat nav is not working correctly. (Strangely, this began a couple days after having the car serviced).
I've tried the infotainment system reset but to no avail.
The maps aren’t up to date, and I initially thought the issue might be related to that. But from what I’ve read, it’s more likely the ’Shark Fin’ is faulty, as they can suffer from water ingress. I’m looking into buying a replacement, but wanted to ask for further diagnosis advice before purchasing. (any removal/installation pointers would also be appreciated)
Also, I want to update the maps, and have looked on the portal, but can only see MIB2 update. So I’m unsure what the correct update is. The car currently has the Amundsen MIB1 head unit, that has the cd player and two SD Card slots, linked to the 6” screen. (I’m considering my options upgrading the (Bolero?) Infotainment system too but will create another post).
The original Škoda SD card is in slot no’ 1. And from what I know, this will facilitate the update. But it states on the portal, ‘Delete all data on the SD card’. Is that correct? And I assume 'or format the card', is related to a non Škoda SD card?
I appreciate this topic may have been covered before, but I’m not the most tech savvy, so any clarification or advice would be greatly appreciated.
Regards
p.s. the car does not have a USB input, only the 'media in' port which I believe needs an adapter to use?
Edit:
Unable to edit the initial post but wanted to change the txt to the following:
'I want to update the maps, so have looked on the portal, and can see the ECE 2020/2021 update, is that the correct one?
I can only see MIB2 Amundsen, MIB2 Columbus, MIB3 update manual info.
The car currently has the (Bolero?) Amundsen MIB1 head unit, that has the cd player and two SD Card slots, linked to the 6” screen. (I’m considering my options upgrading the Infotainment system/ head unit too but will create another post).
Edited by Shkodal
You hv a NAV button so you have an Amundsen
MIB1 map updates stopped 5 years after the MIB1 ws last used in production, which was early 2015 - so the 2020/2021 update is the most recent available for MIB1.
Thanks fella, didn't realise the Nav button differentiates it as an Amundsen.
Didn't know the MIB1 map updates had stopped either, that would explain why I couldn't see updates. every day's a school day.
I'm considering my options regarding an upgrade of the Infotainment system/ head unit/MIB2/MIB2.5 etc. So I've been reading related posts, but will likely do a separate post to hopefully get confirmation of what will work, and what is involved.
In the meantime, I may well attempt the ECE 2020/2021 map update. Will I need to 'Delete all data on the (Skoda) SD card’ as per the portal instructions?
Thanks again for your reply.
Much appreciated.
Edited by Shkodal
Much appreciated.
Yes, you will need to delete all the data. It's a good idea to back up the files first if anything goes wrong, then you can just copy them back
Thanks, much appreciated.
Hi Ords, unfortunately I'm having problems with this. Initially I was unable to copy the folders to the SD card due to 'no disk space'. Which I've managed to sort (including having to delete unneeded Ukraine map data).
I deleted the 'Dbinfo.txt' and 'Markets' on the original SD card. And have copied the same from the unzipped portal dload on to the SD card.
Now when trying to update in the car SD slot, it's not reading the files.
Do I need to copy the contents of the map data folder directly onto the SD card?
There are also drop down subfolders within the main folder though, aren't they all required for the update too?
As far as I can remember, I also had to delete some countries to make space and then just copied over all the files without the dropdown menus open
Thanks, yes, apologies, I only added that last pic as reference to the subfolders which I assume are all needed as well as the map regions data files.
After deleting the items on the original SD card. I copy & pasted over the two unzipped portal update items that look identical to the ones that were on the original SD Card (see pic). Is that how/what you mean?
Not sure why it's not reading the card as it's the same two items as they were, albeit the new update file and folder items.
I'm kinda stuck here, and currently without any Nav at all, as I haven't tried copying back the original 2 items since sorting the disk space issue, prior to which, it wouldn't perform the task.
Your help is most appreciated as I'm not the most tech savvy.
Yes, that's what I meant. Why it's not working I don't know.
