Strange Electric Window Behaviour - Passenger & Rear Windows Respond Incorrectly
Hello everyone,
I am having a strange problem with the electric windows in my Skoda Fabia Mk1 (specifically the 2006 model with 4 electric windows) and would appreciate some advice.
Here is what happens when using the switches on the driver's door:
  1. When I open the front passenger's window, both rear windows close simultaneously.
  2. When I close the front passenger's window, both rear windows open simultaneously.
  3. I can not control either of the two rear windows. The switches don't seem to have any effect. They also feel feather light without any weight to them.
The front passenger's window switch works perfectly, it opens and closes the window normally.
As for the rear switches, their individual door switches can open the windows but they can not close them.
I have already tried replacing the front driver's window motor twice, as a mechanic told me he was about 90% sure that it was the culprit. However, after replacing it, something even stranger happened: I could only open and close the front passenger's window using the driver's window switch. None of the other windows responded to the driver's switch at all.
I haven't checked the wiring yet and, so I'm wondering whether damaged or crossed wires could be responsible.
Another thing that might be worth mentioning is that the driver's window switch isn't genuine. I believe the other switches may be aftermarket as well but I also tried a genuine driver's switch and the problem remained the same.
Has anyone experienced or come across anything similar?
Could this be a wiring issue, a problem with the comfort control module, incorrect switch wiring, or something else entirely?
I'm running out of ideas, so any suggestions or advice would be greatly appreciated!
Thank you!
Hi and welcome to the forum.
I would start by checking the wires where they pass through from the drivers door into the body of the car.
Both the wires themselves for fraying that’s causing a short circuiting and also the connector blocks for water ingress and corroded pins.
Both are very common problems with older cars and cause all sorts of weird behaviours.
Is this a RHD car?
If so, do you currently have motor module part number 6Y2959802A, SK240D4DRS
(both numbers matching totally) fitted on driver's door?
These are extremely rare, so I'd imagine you have an incorrect part there. Do you still have the original one?
If LHD it should be 6Y1959801A, SK240D4DLS on driver's door instead.
Edited by Breezy_Pete
16 hours ago, Breezy_Pete said:
Is this a RHD car?
It is LHD. The part number of the motor module (driver's side) is 6Y2959801.
Edit: VW240PDLS
Edited by ihatemyfabia
I haven't checked them yet but I will have to then.
When checking the cables, what should I look for though?
Edit: VW240PDLS
So, passenger side module from a 9n Polo with only two electric windows.
That will never make the system work correctly in your car.
Don't worry about the wiring.
Hm, that's interesting. None of the electricians even mentioned that.
So would I have to look specifically for 'SK240D4DLS' or just one that comes specifically from a VW group that has 4 electric windows.
You had mentioned also the 6Y1959801A code (instead of 6Y2959801). I have found one but it was from a 2003 Fabia so I thought it wouldn't match since it's pre-lift.
Is '29...' the wrong model to look for then?
Match 6Y1959801A and SK240D4DLS both exactly and entirely. Will only come from a facelift mk1 Fabia, LHD, with 4 electric windows.
A 2003 Fabia would have a part number beginning 6Q instead of 6Y. Different in a few ways and not compatible.
I haven't tried any motor besides the 6Y2959801 so I will look for a 6Y1959801A then, although there's like almost none available in my area.
I have managed only to find a 6Y1959801 on the web but the shop is closed at this time, so I am not able to call them to make sure yet.
If this one fails again, I think I will just disconnect the two rear motors, so that I can at least use the two front windows freely.
I guess you didn't answer the question about still having the original motor because you threw it away?
Which country are you in?
