Passenger side mirror won’t unfold
Went out to the car this afternoon to pick the kids up from school and the passenger side mirror didn’t unfold. Flicked the switch a few times and no joy.
Tried gently pushing it as unlocking the car to see if it could help it and and it seems it doesn’t try to open up at all.
It can be moved by hand but it’s not moving the motor, just moving it off its position. If that makes sense.
Anyone had anything similar or is it terminal?
Shine a torch at the interior mirror, is it wing still dimming? Could also try heated function too
Just wondering if motor is dying and it’s tripped a fuse or so
Edit: Just checked and that’s fuse 39, looks like if that went you’d have issues with central looking on passenger side
Still be worth checking the dimming and heating works though, does the mirror movement still work? If all good guess it’s just the motors had enough
Must admit mine sounds a bit “dry” sometimes like it needs more lube, but never bothered to look
Edited by Danoid
Doesn't dim as its been replaced with standard glass when I broke it but will give the heating a go. The puddle light that side still works. Will try the adjustment too.
I would have thought if it was fuse would both mirrors be affected?
There’s two different fuses depending on side of car, but yeah it’s not that unfortunately
Just scanned for fault codes and got a few come up. It feels like it tried to move a bit but is stuck. Will try to take cap off tomorrow and see if I can see why it’s stuck or anything obvious.
Replacement mirror unit installed and now all working again with no error codes.
Recently Browsing 1
