Battery light 1.0 mpi 59bhp
Latest info looks like this one "1.0l petrol engine with start/stop system , DKLD,DKRC,(7L6) From November 2019"
Only difference is in cars with adaptive cruise control where the green/yellow wire goes somewhere else:
* For models with no adaptive cruise control (ACC)
*2 For models with adaptive cruise control (ACC)
Not totally clear to me whether that extra connection is instead of the one to the BCM or as well as; the former I think.
J533 defined as - J533 Data bus diagnostic interface.
Does your car have ACC?
No ACC
21 hours ago, Tqm said:
Battery is 2 weeks old
Was the new battery coded to the car after fitting?
Thanks. AG Falco
No it wasn’t. Its exactly same spec but different make. Would that affect the battery light?
Probably wouldn't cause your issue with the alternator indicator light - but very likely to affect correct battery charging.
Whereabouts are you based?
monmouth, South Wales
Car’s in for an mot on Tuesday but I’ll ask them to hook it up to the computer aswell/instead
If you were to unplug the LIN connector from the alternator while engine is idling on driveway, that ought to trigger the charging system warning light, I would think?
Recently Browsing 1
