Rear brake pad carrier bolts-removal techniques
Does anyone have a technique or tool suggestion for removing the rear brake pad carrier bolts on Octavia mark 4 1.5Tsi. I work on my drive with a trolley jack and axle stands. I have a breaker bar but I don't have clearance anywhere. Thanks for reading.
Have you wound the pistons back with a ODB tool ?
Edited by RADIOTWO
Yes. All went fine with caliper. It’s the carrier bolts that defeated me. If I were just changing pads I would have been fine. I need to change the rotor too and this cannot be removed unless one first removes the carrier. Two very tight bolts in very awkward position.
Da hilft nur eine Knarre.. verlängerung.. evtl. Kreuzgelenk... Viel Kraft und ein Hammer.
Die Scheibe sollte vorher locker geschlagen werden. Viel Kraftaufwand und Sehr Gutes Werkzeug (14er)
Recently Browsing 1
