Engine Overheating
Hello! I have a Octavia MK3 vRS, 2.0 TDI, engine code CUN
The engine is overheating, 15k kilometers (~10k miles) since timing belt job (incl. water pump and oil pump belt). *No coolant leaks*. The parts I used are all Continental. What brand of water pump do you recommend? Or should I switch to a mechanical pump instead?
Before you go down the water pump replacement route consider that it could be caused by a couple of other things:
  • Air in system. I've heard it can be difficult to get all the air out after replacing the coolant.
  • Thermostat stuck closed or some other blockage in the system
What indications are you getting that it's overheating?
Recently Browsing 1
