1.6tdi revs high at idle after driving car short distance/DPF???
Hi have a 12 plate 1.6tdi cayc and when starting car from cold it idles normally at 750rpm (-3C today) If I drive a few metres then idle jumps to just under 1000 even with engine cold and also once hot. Thought it must be DPF regen but never had it when engine stone cold. Took for a blast down dual carriage way yesterday at 2500rpm for about 30mins at full temp and idle returned to normal. Started car today and idle was 750rpm while defrosting it then as soon as I moved car it jumped to 1000 again and stayed that way. If I turn car off and start again its 750rpm till I move car. Got home from town and the tell tale fans on after engine switch off so reckon its a regen again. What could cause it to try and regen all the time. Is there a sensor I should be looking at. Scanned with cheap reader and no codes plus no warnings on dash.
Alasdair
yeah, thats the dpf trying to get a regen done.
mine does it pretty regularly since i stopped driving it for work (stupid fleet management taking my mileage off me for a van...)
so once a fortnight i bring for a run to let it blow out or force one through my carista if its getring very high
Same here used to do longish runs but now all fairly short. It used to wait till engine upto temp but now seems to do it from cold plus a good blast yesterday seemed to cure it. This morning was the same again?? Seems to be regen every time I start car?? Apart from that car is running perfectly
Alasdair
Mines does the same but also get strong exhaust smell. Only in winter the smell but the high rpm is regular due to short runs.
Weird it has done it the last two/three days in a row even after a 30min blast down road.
Alasdair
Does it if the battery charge is getting low, particularly in cold weather. May be first sign of battery getting tired.
Ah that might make sense re battery. Think its about a year old but cant remember if I bought a new one or nicked a good one from one of my older cars. Will check voltage tomorrow. The high idle has only been there for the last few cold days -3C and below and only today did it fail a regen hence fans on. Previously it just sat at high idle but no signs of regen or fans. Its supposed to get a bit warmer tomorrow (a balmy 4 degrees!) so will monitor it plus give it a good run when I can. Cold weather is hard on batteries so hopefully thats it and nothing more sinister.
Alasdair
The voltage is just a crude indication. Better if you can find a place that do a capacity check.
Recently Browsing 1
