Facelift taillight retrofit
Hi everyone!
I’ve wanted to install the FL taillights for a long time. They fit perfectly in terms of mounting points and are plug-and-play (pin-to-pin). However, when locking and unlocking the car, I was getting turn signal errors, and the animation wasn’t working.
I fixed the turn signal errors by changing the Leuchte 18 and 19 parameters. I replaced the pre-FL lamp type “LED Blinkleuchten mit Ueberspg absch” with the FL setting “LED Kleinleistung ohne Open Load Diagnose.”
The turn signal errors are now gone, but the animation still doesn’t work.
Does anyone know if the animation can be made to work? Is it coded separately? Does this LIN version support it?
Recently Browsing 2
