Coolant level warning mystery
I was hoping someone could give some help in tracing what's causing my coolant level warning on the dashboard.
It's a 2008 2.0 diesel. The warning is the three beeps and the red light flashing on the dashboard.
(1) The coolant level is correct;
(2) I've replaced the expansion bottle which came with a new sensor which made no difference to the problem;
(3) the contacts to the sensor in the expansion bottle look very clean;
(4) the engine is not running hot, the warning usually comes on within a minute of starting from cold;
(5) the temperature gauge is working as normal.
Sometimes the warning doesn't happen, usually if I've driven the car, left it for an hour or so then started again. This could be random as I've only had the problem for a few weeks.
Assuming the level sensor is working as I've replaced it, is there another sensor that can cause the warning, I'm thinking one that says the engine is too hot, that could be faulty? Or is this the same as the one that operates the water temperature gauge on the dashboard?
Is there anything else that I can check?
Thank you.
If the tank is new it should rule out dirty sensor prongs in tank. I would check the wiring from the plug backwards to see if its broken somewhere and also check plug terminals are tight and making good contact. I think it goes to cluster so maybe a dry joint bad connection there?
Alasdair
Thanks Alasdair, I'll have a look. Does anyone know if it is safe to short out the plug to the sensor, and if so if the alarm still shows it must be the wiring?
Recently Browsing 1
