Coolant level warning mystery
I was hoping someone could give some help in tracing what's causing my coolant level warning on the dashboard.
It's a 2008 2.0 diesel. The warning is the three beeps and the red light flashing on the dashboard.
(1) The coolant level is correct;
(2) I've replaced the expansion bottle which came with a new sensor which made no difference to the problem;
(3) the contacts to the sensor in the expansion bottle look very clean;
(4) the engine is not running hot, the warning usually comes on within a minute of starting from cold;
(5) the temperature gauge is working as normal.
Sometimes the warning doesn't happen, usually if I've driven the car, left it for an hour or so then started again. This could be random as I've only had the problem for a few weeks.
Assuming the level sensor is working as I've replaced it, is there another sensor that can cause the warning, I'm thinking one that says the engine is too hot, that could be faulty? Or is this the same as the one that operates the water temperature gauge on the dashboard?
Is there anything else that I can check?
Thank you.
If the tank is new it should rule out dirty sensor prongs in tank. I would check the wiring from the plug backwards to see if its broken somewhere and also check plug terminals are tight and making good contact. I think it goes to cluster so maybe a dry joint bad connection there?
Alasdair
Thanks Alasdair, I'll have a look. Does anyone know if it is safe to short out the plug to the sensor, and if so if the alarm still shows it must be the wiring?
Not sure re shorting out but from memory I think you should have 5-6v on one wire and the other is earth. You could check if theres voltage using multimeter on +ve wire and use chassis as earth then check continuity of other wire to chassis. Could be as said broken wire or dry solder joint somewhere. Also check the temp guage isnt fluctuating as I think its the same warning for engine overheating. Could be a bad G62 coolant temp sensor.
Alasdair
Thanks, I'll try and check. The actual temp gauge seems fine at the moment.
If you still have the original reservoir, maybe check the level sensor connector pins - just to make sure that coolant is not breaking through and being forced up along the cable.
I've seen that being reported as causing some problems, maybe unlikely, but worth checking anyway if only to be able to dismiss it.
The original reservoir and it's connections al look spotless, but I'll double check
