Fabia Fuse box
Hello,
Could someone please tell me where i locate the fusebox on a Fabia comfort?
and which fuse is connected to the cig lighter.
Many thanks
Alan
Try looking at the side of the dash, drivers side. There should be a small slot at the lower edge. Put the car key in and gently lever off (all clips) pull off and there you are.
Look at Stu's site fabia-vrs.com for the fusebox layout.
HTH
Bas
PS the ciggy lighter is turned off if you have the childproof window locks turned on!
What an excellent feature!
  • 8 months later...
Hopefully a simple question - how to tell fuses controlled via ign switch??
Test lamp or multi meter, what you after?
Just a thought looking at panel - for future use of any unused fuses ---classic must have a few -something like remote locking - with ign on disabling to prevent hatch release on the move.
Don't like poking fluke in fuse panels -shorts are too easy to get- thought there might be some logic to numbering .
Was referring to the diagram on VRStu's page
