DPF - no DPF / 8v - 16v
When choosing my new Octavia, I have the option of choosing a car with or without a Diesel Partikel Filter.
Cost is not the issue, since it's only ~250 euro extra. However, I read on a German forum that there is actually a difference between the engines. Both 140 BHP / 320 nm torque, but the one with DPF would be an 8 valve engine where the non-DPF version is a 16 valve.
Paying more for getting less?
When asking the dealer this afternoon I got a vague answer about a not noticable difference in performance between the two. It's not in the technical specifications either.
Someone can confirm this?
source:
http://www.motor-talk.de/showthread.php?forumid=306&threadid=679311&perpage=15
I seem to have found my own answer on the German Skoda site:
http://www.skoda.de/index.php?e=1-24-4-7
2.0 TDI PD: 4-Zylinder-Reihen-Dieselmotor 2 OHC 4 Ventile / Zylinder
2.0 TDI PD DPF: 4-Zylinder-Reihen-Dieselmotor 2 OHC 2 Ventile / Zylinder
2.0 TDI PD DSG: 4-Zylinder-Reihen-Dieselmotor 2 OHC 4 Ventile / Zylinder
2.0 TDI PD DSG DPF: 4-Zylinder-Reihen-Dieselmotor 2 OHC 2 Ventile / Zylinder
for the non-german-readers: Zylinder = Cylinder and Ventile is valves :)
In Holland, this is nowhere documented. I find this slightly misleading, specifically after asking the dealer. I will definitely go for the 16 valve engine. No DPF it is.
That's worth knowing; thanks for posting the info when you found it :thumbup:
Hi!
I'm living in Sweden and I have a 2.0 tdi dpf. I've tested both versions, 8v dpf and 16v without dpf. The 8 v version has better torque in lower rpm:s so I really prefer that one. And it's better for the environment to. So I recommend the dpf version. Also oilconsumption has been very low, 0.3 liters for the first 10.000 miles.
Best regards Anders Pihl
