Skoda Stream Bass settings etc
Anyone managed to find (or know) the optimal settings for treble, mid-range and bass?
depends what music u listen too
I don't think there is an optimum setting. It's just a case of sticking in some cds and playing around with the settings, that's what I did and took me a few goes, but got there in teh end.
This works for me:-
Treble +1
Mid Bass 0
Bass +2
The best way to work out what is right for you is to put on a favourite piece of music, preferably with a bit of bass content and adjust the settings with your eyes closed!. :thumbup:
The temporary stream unit I am currently using, doent have a midbass setting just bass and treble. These I have all set to 0. The audience has a midbass setting.
Still should have the audience installed at the weekend once the dealer gets the codes from Skoda, at least he has the new HU now.
Cheers guys. I kinda thought it might be down to personal preference.
The temporary stream unit I am currently using' date=' doent have a midbass setting just bass and treble. These I have all set to 0. The audience has a midbass setting.
Still should have the audience installed at the weekend once the dealer gets the codes from Skoda, at least he has the new HU now.[/quote']
The later Stream's have bass , mid and treble.
I have Bass on full , treble on about +2 and mid flat
Bass +2
Mid -2
Treble -2
Seems to work with most of the cr@p I listen to.
I like bass so had my bass on max and treble on 2. Problem was that the speakers and / or door cards started vibrating, not just at loud volumes. Took it to the stealer expecting them to take off the door cards and check for loose components - but no - we've turned your bass down sir. To55ers
Treble and Bass just alter the amount of hiss and vibration respectively and the Stream HU doesn't have any mid-range, so that control is pretty much redundant.
It sounds rubbish at any setting. Some just sound a bit less rubbish than others.
the Stream HU doesn't have any mid-range' date=' so that control is pretty much redundant.
[/quote']
Of course it has midrange. Just not very much of it.
Treble and Bass just alter the amount of hiss and vibration respectively and the Stream HU doesn't have any mid-range' date=' so that control is pretty much redundant.
It sounds rubbish at any setting. Some just sound a bit less rubbish than others.[/quote']
Certainly isn't as good as the 8 speaker set up in the Fabia estate I had, that's for sure.
The sound in the Octavia isn't that bad
If you play the right music the speaker give out a considerable kick.
My old man had a Volvo 240 Estate and the speakers in that were the size of those little foil mince pie dishes, they sounded like them too. :rofl:
I have mine on bass +2 midrange 0 and treble +1.
What I find annoying is that the vocals seem to be very right sided and I have to set the balance to -5 i.e. to the left to get a good stereo effect.
Had a problem with the left bass speaker but this has been fixed at the stealers today - apparently it is a common insulation fault.
treble -4
mid -9
bass 0
for radio 1, indy and rap. have i got a bum sream mp3 or am i deaf ??? bass speaker prob what was the problem
I have
treble 0
mid -4
bass +2
and loudness off.
I also have DLS components in the front doors and DLS coaxials in the rears.
Better than nothing I guess.;)
