coolant light flashing and 3 beeps
got in the car this morning i put the keys in the ignition turned them but i did not start engine so all lights on the dash were on whilst i rolled a fag.
Suddenly i get the coolant warning so knocked igintion off popped the bonnet unscrewed the water bottle there was i tiny hiss level was fine, so i did it back up
tried it again and all was fine drove to work lovely.
So i am just wondering what all that was about any thoughts anyone
Hi
The expansion tanks on these have a sensor in them , and the sensor is usually at fault if the level is fine.
It is saying that the level is low , when in fact it isnt.
I think it could be the expansion tank that requires replacing.
It is quite a common fault.
If it does need one , it is not too big a job and they are not that expensive if you go to GSF
May also be worth thinking about a seal for the cap too while your at it
Sarah
Mine used to do that on cool/cold mornings if parked on a slope with the car facing up the slope.
As soon as the car was level I'd turn off then re-start and it was fine.
Just add a smidge of coolant and it'll be fine.
Hi
The expansion tanks on these have a sensor in them ' date=' and the sensor is usually at fault if the level is fine.
Sarah[/quote']
i am dull whats GSF
i was facing up the driveway on a slight incline i'll put a drop of water in later
GSF = German , Sweedish and French
Sarah
:thumbup:
nice one thanks for your help
Mine did exactly the same thing.
Darn those sloping driveways.:P
I had this, told the dealer r.e. sensors and expansion tank replacement (I was under warranty at that stage), he told me just to put a bit more coolant in. Its never done it since. :)
