Any Vag-Com Experts ..
... out there know if you can re-set the service light on tavia mk2's with Vag-Com
I think so, I'll have to have a better look at the weekend though
Can you reset it with the reset button whilst starting or is that just the reset for the counter until the service.
I reset my counter accidently, so if above doesn't do it then my light should still come on at 10k miles.
Perhaps you should "ask a Tech" that way someone with some knowledge of Skodas will be able to help.
Bloody ameteurs :rolleyes:
Been here?
Ross-Tech: VAG-COM: VW Service Interval Reminders
FWIW, if you disable the reminder "manually" by using the buttons on the cluster, you are switching to non-flexible (non-longlife) service intervals. So if in doubt always use the diagnostic method.
yes probably but tech's with lots of skoda knowledge will probably be using the offical 1552/5051 machines won't they !
Been here?
thanks for that, most helpfull unlike certain members :rolleyes: but that is for the old tavia and fabia's, the new octavia i'm led to belive uses a different method on the 5051 diag machine and the 1552 machine isn't capable of re-setting hence my original Q but thanks anyway.
If this method would not be suitable for your car, I wouldn't have posted it.:cool:
You have PM Chap.
You have PM Chap.
PM's suck - ehy don't you post right away here?
i take it that you have sucessfully done this on a mk2 octavia?
Yes.
i have been reliably informed by someone in the know that you can't use the same process for the octavia mk1's and the fabia's (of which i know off by heart, and the link that you put on the forums leads you to the same set of instructions).
I have no clue what your reliable source is, but your source is wrong.
So can you confirm that you have been able to do this ?
Not sure how often I have to say this, but this will be the last time I'm wasting my time with telling you that it works. So yes, I can confirm that.
Yes.
Then Thank You Very Much For Your Help.
May be a silly question but are you using the correct cable that's compatible with the Octy Mk2?
Big K ,,,,, don't worry about him ,,,,, he's German!
