Wheel alignment on 4x4?
Having lowered my car the rear wheel have a lot of negative camber on them...
I have looked on Autodata they say the rear camber is not adjustable, is there any way around this?
Also does anyone have any settings other than standard that they use for better handling?
Cheers:)
Adjustable Tie rods need to be fitted, I bought some off of Forge 3 years ago for about £250 + the dreaded + postage :eek: :eek: :eek:
I believe Jabba may be able to source them for less, They are made in the States & are meant for TT's but fit the 4x4
Powerstation in Cheltenham are excellent at 4 wheel allignment if you are that way, I travel from hampshire just to get the wheels aligned there
They can dial in or out understeer to suit what you want, they have vast experience with rally & race cars so tend to use their knowledge rather than a book
Hi mate, they arent adjustable as standard but speak to the nice people at Jabba and they will sell you a set of adjustables rear control arms which when fitted, allow camber to be adjusted. :)
Its what I have and they work brilliantly.
Lee
cheers guys, will be on the phone to them then! Doing 800 miles this weekend though so might have a rather rough ride (need dampers) and a lot of tyre wear:(
Not wanting to scare you mate but have a peek at this lowered, non adjusted Passat 4 motion...
Forge Motorsport
:eek:
:eek:
:eek: oh bugger. Might have to pinch the recce car from work if its back from cyprus for the weekend:(
That does not look great!
Do I need anything else before I order them?
Jabba can do a mean set of dampers as well :) :)
If you want to stick with Std dampers I have a complete set in the garage off a 52 plate 4x4, came off the car about 3 years ago, covered 8000 miles from new
call on 07799 623693 if interested
Don't know if these will fit but night save you a few quid if they do.
uk-mkivs
Stuart thats very kind thanks, but I think it is uprated dampers I need really, whilst the ride was quite bouncy before I lowered it the car has only done 40k so surely the dampers can't be that worn? Also there is a lot of weight in the back of the car all the time so I reckon that will make a big difference... If you think otherwise please do say!
JAYMD, thanks for that, unfortunately the link isnt working, takes me to the search page saying the the page you were looking for is no longer available...
Uprated is better, If you can afford it go that way.
I have tried both Kw variant 2 & 3. The 3's are slightly better but cost more (still running the 3's)
Lee (FocusZtec) had a different set up fitted which hes very pleased with but I cant remember what it was. (edited to say, Just read his signature, its all on there)
Forge Motorsport
:eek:
:eek:
Aint that a Skoda in the Forge link?
i have lowered mine and forgot to change the tiebars at the back, my camber is a bit out but haven't noticed any really odd tyre wear and no funny handling either. its been round silverstone twice at trax in '05 and '06 and gets driven hard round the roads. :)
they haven't snapped either ;)
looks more like an S3 to me :)
You will need to sign up to uk-ivs forum to get to classified ads.sorry
i have lowered mine and forgot to change the tiebars at the back, my camber is a bit out but haven't noticed any really odd tyre wear and no funny handleing wither. its been round silverstone twice at trax in '05 and '06 and gets driven hard round the roads. :)
I find it hard to believe they will actually fail, re handling you could find its actually better, Race cars tend to run excessive camber on the rear for cornering & I know of company who sell an uprated version of a std road car (not VAG) who had excessive camber put on the rear of the car when the press tested it on a circuit.(without mentioning it) They did say they wouldnt run that set up on the road car due to tyre wear problems.
I drove a Cannonball with my car lowered but without the bars as I could not obtain any before I went. Nothing broke but one rear tyre was treadless on the inside, that was in about 3000 miles albeit 3000 virtually flat out miles at speeds of up to an indicated 150. The tyre had done about 1000 miles before the event
Strange only one tyre went, I put it down to a combination of tracking & Camber out, I also hit a small sleeping policeman at ??mph, it was hard enough to buckle the front & rear alloy on one side of the car so Im guessing that probably knocked the tracking out on the rear. Thankfully the sump missed it !!
i think that was probably the cause of your tyre wear as mine has seemed normal whenever i look :)
I've got KW v1s without adjustable tie bars. I haven't gone mega low which may help a bit but 8000miles with no uneven tyre wear here. Iirc Demon Tweeks measured it at 2 degrees of negative corner, just on the allowable factory limit.
i might get out a protractor and spirit level one day and measure my camber :D
Fitted new vrs dampers on the front yesterday (only £34 from Skoda!) and that has pretty much sorted the front end. Think I will be going with rear tie bars and adjustables on the back, the toe in and camber are way out so definately needs attention!
Cheers for all the suggestions and will keep updated:)
Powerstation sorted the toe on mine after lowering but it required a serious amount of work with a tapping stick
:thumbup::rofl:
handleing wither.
Is that some sort of grip-loss ?????????? :D
as normal my fingers are too fast for me :(
Not had chance to read the whole thread but like Bengie I had no tyre wear problems when lowered on the H&R springs. However I did on R32 springs as the rear was very low.
