vRS Front ARB & Droplinks
Hi, first post here :)
I'm going to upgrade the front ARB on my Ibiza PD130 with a vRS one. Also putting a Jabba Rear ARB on at the same time :D .
I've been told it will be best to replace the droplinks too?
Is this the right part number (6Q0411315G) and I take it I need two?
Will these definitely fit?
Thanks, and sorry for all the questions!
Sorry I can't give you that specific advice but someone will.
Hi, and welcome anyway. :)
Hi and welcome.
There is a revised part number for the Drop Links which I think is the one you have.
Fabia-vrs.com - Handy Part Numbers
Thanks for the replies and welcomes :) .
I will get 2 ordered tomorrow. Bit more than I expected mind but can't be helped.
Would you definitely recommend changing the droplinks when getting the front ARB fitted? Anything else I should think about changing? The cars got 30k+ on.
I've been researching this topic and this seemed like the best thread to dig up.
I'm looking at replacing the front ARB on my elegance estate for a VRS one. Am I right in thinking the ARB (complete with bushes) has the part number 6Q0 411 303 AE ? I'm also going to replace the droplinks as I had an advisory for some play in these at the last mot. My question is, do I go for the modified VRS ones seeing as I'm getting the VRS arb? or do I stick with the other type? (6Q0 411 315 F is the number I have for the alternative)
These items will be replaced in conjunction with fitting some koni FSDs and eibach springs if that makes any difference. Already done the rears + a jabba arb and very impressed so far. :D
Thanks in advance for any help.
Bump
No one? :(
My best guess is the drop links on the VRS are slightly shorter due to the lowered suspension. So I should really be getting some methinks...
