Phone & iPod mounts - Octy II - Pics
Just thought I'd show you what I've done...
Phone is mounted via a Leather Console from DashMount - CLICK ME
While iPod is mounted via a Brodit clip - CLICK ME
I'm glad you've posted these up for all to see, I was really impressed by that leather phone mount when I saw your car.
Who fitted the Dension ?
I am looking to get one installed into either the Glovebox or the Jumbo box but cn see how I can run the cable without drilling a hole to run the cable connection to the ipod.
I did :D
Very simple - Having had problems with one in a Octy1 I oped for the pucker Skoda one, and then added a standard Dension active holder. I guess you could buy the Dension Skoda version from and get the holder instead of the cable.
Procedure -
Remove trim
Remove Climate control panel (4x trox T20 screws)
Remove HU
Remove changer connection from Quadlock plug
Add Ice>Link connect to Quadlock plug (note mod may be needed CLICK ME)
Feed Ice>Link cable down into space behind climate control panel
Replace HU
Pick up suitable Ground/Earth connection (mine came from behind panel to the side of clove box)
Cable tie Ice>Link module to existing cables behind climate control panel
Using a suitable tool (bent coat hanger or similar) push down to passanger foot well, tape mini din plug (from Ice>Link cable) to end and pull up.
Plug in mini din to Ice>Link control box
Replace climate control panel
Fix iPod holder in place
Push spare cable up behind panel
Test and finally replace trim
Total time required approx 20 mins :thumbup:
Pics above don't seem to be working, btw how much was the cable ?
Sorry the hosting web server is down at the moment - engineers are working on it!... The Dension Active Cradle retails at just under £30.00 CLICK ME
