A list Of Options To Be Enabled Via VAG-COM?
Hi,
The vRS is going in to get its bonnet fixed sometime this week and I fancied getting anything else tweaked while they were at it. I was considering the 'bleep' to unlock, 'bleep-bleep' to lock and the 12mph locking. Anything else to consider? Would be handy to create a sticky of this?
Mark
I have also started to compile a list myself -
Octavia-vRS.com - Octavia II Controller Coding
Stu, I see on your site you mentioned the, Synchronised Mirror Adjustment. Is this the same as on mk1 where adjusting Passangers Side also done the Drivers side ? I think its selected on mine but IIRC it doesn't move both mirrors, unless something else also needs changing.
Also have you a sunroof, I seen mention in a thread about the closing of this when raining (changing it is available in maxidot on Newer models), wasn't sure if thats when car on and it closes itself or if its when car is locked and it closes itself. Any idea what its located under in the earlier model vRS ?
Gaff I don't have a sunroof myself but as far as I know it closes when it rains if you have the rain sensor fitted.
WRT the mirror adjuatment it's a tick box in the location I mention, ticked for enabled and unticked for not.
:thumbup: so it seems the two i want are the only ones really worthwhile. i believe maxidot does a few of those i.e. toggle single door unlocking and the door mirror adjustment.
what codes would i need for these two then and should i even care (the skoda dealer should be able to do it easily if i just tell them what i want?)?
If the dealer is doing it then just ask them to sort it out.
