Help
Does Anyone Know The Drive Ratios For 2nd And 3rd Gears Fitted To The Six Speed Gear Box Of The Fabia Vrs. Have Got A Software Programe From The States Used Via Laptop With Obd Connection To Car Info Port. Need The Ratios To Access Various Info... Any Help Most Gratefully Received. Cheers
Jakesbrakes.
Jakesbrakes.
It's in the worng section really mate but I'm sure it'll be moved.
In the meantime I have this file which I'm afraid I don't know who produced and so can't credit them for it.
gear_ratios.zip
Vr Stu.. Thanks For Info.. Could Well Solve The Problem...
Author was Bryand
Just had a look at that doc and it says the '53 vRS does 152mph on 16" wheels! :eek: That can't be correct surely!?
that is probably the theoretical top speed at maximum engine revs , something the car wont do due to drag etc , the earlier cars had a higher 6th gear iirc , the theoretical top speed for the later cars will be lower
