whats a recommended upgrade for vrs
I was thinking of upgrading my vrs engine spec but only a little.
First of all do these silicone hoses make a difference?
Second what difference does a dump valve make, does this improve power, all I can make out is that it makes a louder noise.
Thirdly a chip would be an obvious choice, how would I check that this mod hasn
If you want to check what power you are running now, a rolling road would be a good start.
Have you thought about visiting the Awesome GTI Xmas Event.
You should also be able to get plenty of good advice from them and other members who may be there on the day
First of all do these silicone hoses make a difference? Nope, but look nice.
Second what difference does a dump valve make, does this improve power, all I can make out is that it makes a louder noise. Just sounds different and can lose you power.
Bmc CDA box with a forge turbo intake-pipe will give a few xtra hp and quicken up the throttle respone in all gears with a light increase in the dumping noise thru filter.
Dump valve will only be a benifit if its a resirculating type (no power increase) just better reliability than original.
Re-mapp will make the biggest diff most quality mapps will be about 3-400 quid and bring power on std car to about 205 ish, with some other mods like Exhaust ect 220-235 is acheivable
Cheers people I think I will try and find out if the car has been chipped. I may take it too the rolling road day, at Awesome GTI Xmas event.
And then go from there.
