Octavia 2003 door lock switch
First Skoda, bought 2 weeks ago. I now realise the drivers side rear speaker doesn't work, the warning buzzer for the lights,door light and the inside light doesn't work because the door switch is faulty, and the rear hazard warning light on the switch doesn't work. I really hope this doesn't mean that the thing has had a swipe on that side and not assembled correctly.
Most of faults point to a faulty switch to the driver's door, which according to the Haynes manual comes with the door lock mechanism itself and is not obtainable separately. Surely this cannot be correct. To have to remove door trim, door lock and buy a complete door lock looks to be
With regard to the lock fault, it may be a "dry joint" on the printed circuit board in the drivers door.
Do a search on here, you'll find full details of how to fix it. Simple DIY job.
