WW_VRS' Fabia vRS
Right - time to get this built up as my signature is running out :P
'05 registration Fabia vRS in Black Magic.
Remaining plans/things under investigation:
  • Aquamist water injection to get my EGT under control - On hold
  • EGR sensor/gauge - to be fitted, just not had time
  • pre 1973 Show Plates for BRISKODA events - in the car ready for the moment
  • First Rolling Road results - Superchips RR done
  • Green backlit controls for my sunroof-equipped Furby, much like the W8 - WIP
  • Another custom mapping. Will do an APS-based Superchips one on a new ECU to get me going quickly Done, 201bhp, some torque too :P
  • Uprated PD injectors by Kerma TDI - arrived
  • Heated washer nozzles - WIP
  • Eberspacher or Webasto car pre-heater - on hold
  • Full replacement of all OEM turbo hoses/fittings with Forge equivalents - on hold
  • Stealth EGT-removed pipe, keeping the safety shutdown - Not gonna happen as CEL would be lit
  • Retrofit full climate control - unsure which donor car to use though? Got the display unit coming at some point ;)On hold
  • Additional oil/fuel coolingOn hold
  • Other crazy ideas ;)
Factory/Skoda accessories/options:
  • 6 CD Changer
  • Heated Seats
  • Electric Sunroof
  • Xenons
  • Passenger airbag de-activation switch
  • Side airbags
  • Under-shelf storage - uprated with cable-ties when it ripped...
  • Side storage bags
  • ESP
Handling:
  • 312 mm Audi TT brake kit as supplied by Golfturbo and fitted by VRStu, painted by myself using nothing but the best hammerite smooth green ;)
  • SEAT strut brace, painted black magic professionally
  • Jabbasport rear ARB, painted matt black professionally
  • Eibach Pro springs
  • Koni FSD Dampers
  • Quaife ATB Differential
Performance:
  • Turbodynamics Phase 2 hybrid (MD446) for the PD130 engine
  • SEAT PD160 air intake
  • Green Filter
  • Superchips Custom Map
  • Sachs Organic uprated clutch with uprated pressure plate
  • Powershot Propane Fumigation system by Chris from PI Fuel Systems - turned OFF
  • Metal impeller waterpump
  • Forge FMIC
  • Blueflame full system exhaust
  • Some powerflex bushes/Udder mod
More stuff:
  • Forge Oil filler cap
  • Front and rear mud flaps
  • Aluminium sump protector with custom made bracket to fit around the Forge FMIC pipework
  • Parrot CK3100 Bluetooth Handsfree kit
  • Briskoda Tax disc holder
  • Miniature Briskoda logo behind the sunflap in the middle at the front
  • To be fitted - larger Briskoda sticker for the rear window as supplied to Freedom members
  • LT450 Garage Door Opener device
  • Talex - still need to get round to renewing it and actually using it though
  • Uprated high beam & side lights
  • Indicator bulbs without the orange look to make it look a little better
  • First aid kit
  • Emergency tyre repair kit
  • Warning Triangle
  • Fluorescent jacket
  • Michelin tyre inflator
  • Euro headlight converters
  • Twin-cup holder mod
  • Skoda logo'd (sp?) dust caps
  • Full exhaust heat wrap
  • Full heatshielding of remaining air-feed pipework/hoses
  • Electronic boost gauge with sensor tapped into the manifold
  • Baffled sump
Links:
Briskoda RR day 20th Jan 2007 at JKM
Clicky for de-egged indicator bulbs (thanks Blade404)
Boost gauge
EGT gauge
PI Fuel Systems
Custom Code
Turbodynamics
Remote oil/fuel cooler
Heated nozzles
Eberspacher comfort heater
Chipped UK
Awesome GTI
Aquamist main site
JKM
15253.attach
Piccies?
Will get some soonish, it looks like a standard vRS that is on Eibachs pretty much though.
Assuming I can get the splitter supplied & fitted at APS I may try to make some snaps then :D
Updated details again, need to empty the boot and tidy up the car this weekend, plus do a bit of driving :P
That's one tasty spec sheet - std looking eh - bit of a sleeper/Q-car look then? :rubchin: :eek: :rofl:
Great work mate....
Steve
It's basically standard looking, it's very slightly lower, and the exhaust is a minor hint, although it's not 'massive' or anything. For the rest it is totally stock from the outside.
Not a lot of visible stuff TBH :) Seems to be going rather nicely now though ;)
Exactly what I like! I can imagine a few other road users take exception though! :P :thumbup:
Steve
  • 11 months later...
Well this one is not in a good state any longer, thought I'd post about it.
The wheels are shot to pieces annoyingly.. The car is a cat C write off due to a meeting with the central reservation a while back.
Will start a new thread on my 'new' car ;)
