brake pad sensors
just a quickie
do octy rs's come with brake pad sensor's as standard
As my pads look a little low will i be notifed by the car when thier goosed.
I think they do.
Simple way to check is to look for the wire coming from the pads.
That said if you think they are low then you should consider changing them.
yeah they look ready and if the dealer records are right they've done 46k
which aint bad
i'm just waiting for my mate to get his new garage open and i'll fit them myself with him watching over me for when i balls it up
i suppoe the wire is round the back of the pad in which i aint checking today cos it's lashing down
It comes out of the outer edge.
cheers stu
you havn't got a photo by any chance have you
It's obvious. And it's only on the front nearside wheel, from memory.
I've not, I did a quick google but without success.
These are the pads, if fitted the cable would exit in the area where you can see the gold coloured bit -
In this picture you can just see a plug lurking -
Also be aware that it can be disabled in VAG-COM so you shouldn't trust them even if fitted unless you know they are enabled.
Apparently just on the inside pad as well...
ah ha nice one chaps
ill get this checked out tomorrow cheers
Yes the sensor is on the n/s only and on the INSIDE pad on the INSIDE edge.
Not ver clever if your pads happen to wear quicker on the o/s
