induction kits, plugs ,discs advice
with my beloved octy rs due a service soon i might aswell upgrade some parts so just after some advice really any would be good thanks
1
has anybody had any experience of the k&n 57i kit as the kit isnt to badly priced or has anybody used one of those induction kits on ebay at the moment (quickshift i think there called) or even the pipercross ,
eBay.co.uk: QUIKSHIFT Induction Kit Skoda Octavia RS (item 180069210511 end time 08-Jan-07 23:45:00 GMT)
2
which spark plugs are the best to use
3
seen some discs on ebay (again) £130 for 40 grove front and rears ,anybody used thesehttp://cgi.ebay.co.uk/SKODA-OCTAVIA-VRS-RS-FRONT-REAR-GROOVED-BRAKE-DISCS_W0QQitemZ200066008932QQihZ010QQcategoryZ23013QQrdZ1QQcmdZViewItem
Hey Glen. Cant really offer you the help you're after, as i'm after pretty much the same info, however...
I've only just bought my Skodie, quite some change from the Rover I was driving. I did have one of those 57i K&N kits fitted to my 216Si, with very pleasing results. I never needed to change my air filter in the 4 years I drove it, just cleaned it once every 2 years.
In the Rover I really appreciated the noise that came with the 57i kit, however, I think in the vRS i'd rather be without the noise and so may just fit one of the standard K&N filters that fit in to ur existing air filter box
just replacing the filter in standard box is another option i am looking at aswell ,decisions ,decisions eh
Decisions indeed. I mean, you have to consider things like - would the 57i give you noticeable performace increase over the filter in the standard box? and if so, would it be enough that you could live with the noise? Maybe (most probably) the noise you'll get with a vRS is going to be substatially better than that which I experienced with my rover anyway.
Ho hum
only reason i asked have had k&n filters on old rs turbos and other cars and they have always been ok (a little noisy but ok) but when you compare the cost against say the carbonio i think its called then theres abig difference price wise for how much performance
K & N 57 i has actually been proven to lose power and screw up your MAF, too oily, the best intake for performance and airflow, although no noisier, is to smooth the existing airbox and put a green panel filter and cool air feed tube into the std airbox.
If you want lots of wooshing and chuffing on gearchange a CAI from EBay does the job only get a Green cone filter tpo replace the one supplied as they are not st st mash and rust away.
How exactly do you 'smooth' the airbox?
