brakelight switch
Almost certain my brake light switch has gone faulty. No brake lights except the high level one and my glow plug warning light is flashing.
How do I find the brake light switch and how do I change it.
Cheers.
Is your car under warranty? A new (purple) brake light switch was introduced a couple of years ago, and you may be able to get a warranty replacement. Otherwise, a search will produce fitting instructions.
Had a search but can find instructions, my car is out of warranty. I know it only takes a few mins to do, just find a few pointers to get started.
When the brake light switch fails , all the lights dont work
Check the bulbs out first
Check your bulbs first, then find someone with vag com, as it should highlight the switch, or just replace the switch anyway, its quite cheap and easy to do
Be aware of THIS service bulletin though before attempting to fit the switch. :thumbup:
Silly me, it was the bulbs that had blowen, not the switch, just seemed strange that both light weren't working. Bought myself a switch as well £7.50 THEN checked the bulbs, any way all working now.
