Horrid beep when braking!!!!
Hi,
Had a problem with my VRS, everytime I braked a loud beep would sound and a bulb out light would come on.
Checked all brake lights and they work fine.
If you guys/dolls have had the same problem and now it is driving you mad. Just find the fuse for the control unit for lamp failure and remove it..............SILENCE!!!!!!
Good Luck!!!!!:thumbup:
check to make sure that you have the right type of bulbs in, iirc if you have a 21W bulb one side and a 5W bulb on the other it confuses it into thinking one has blown
Hi,
mmm, checked all the bulbs and they are all correct. Might be the third brake light causing a problem which is common.
Anyway, fuse out, no harm done and silence.
I don't remember mine beeping when I had a bulb out (about the only thing it didn't beep for! :rolleyes: ) ... have you checked brake fluid level? :D
Chris
mine does beep when one of the bulbs is out..... but i think it depends on what spec car you have
