Where is my ECU??...
Hello,
Just read on honest ohn's site "Power loss on TDI 110s down to same problem as on Golf Mk IV. VAG acknowledges a fault with the ECU (038 906 018 BM) and specifies an upgraded unit (038 906 018 GQ) at
Underneath the scuttle panel I would think.
Under the scuttle pannel, right in the middle.
Does anyone know if vag-com can pull the ECU number out?
Dealer tool pulled mine so i would guess VAG com might be able to...
Yes, VAG-COM identifies the part number of each controller when scanning each address. The engine ECU is the first part number identified, eg 06A 906 032 HJ for the 1.8T ECU fitted to my 4X4.
