It's getting HOT in here!!!!!!!
Having a problem with my heater (Fabia VRS). It heats up fine, but once warmed up, I can't turn it down! Even on min temp it's still blowing out hot air. Any ides?
Luko.
Search for threads regarding Flap Motors.
had the same problem with mine and as stu says i had the flap moters replaced and all is well now
  • 2 months later...
This one's easy...
Open the window! :P
I'm having similar problem.Both with and without aircon switched on. Usually I finally manage to get temperature down but there can be a long delay. It seems if the temperature control is left for a few hours temperature is maintained OK so long as it is not readjusted i.e.turned up or down. How much for these "flap motors" ?
About £90 each IIRC.
There is more then one than, you need to make sure you get the right one.
Mine had opposite problem and after long vivists to crap Kia dealer (where i bought the car) it was eventually decided the thermostat was brok. Luckily it was still under warranty and problem hopefull been sorted but like i say was opposite to yours, ie didn't warm up.
I've just got used to it :o
But I tend to heat my car like an oven anyway, so it is not that much of a problem.
and the passngers fall asleep ? :rofl::D
