Felicia Rev counter
Hi
I wonder if anyone can help with this problem
My felicia GLXI tacho is behaving very strange - under about 2500 rpm it is reading zero. between (I guess) 2500 -3000 it is reading more or less normal and over (again I guess) 3000rpm it is readdign about 4500.:confused:
It has previously worked OK other than very occassionally behaving a bit like this but then sorting itself out........
Does anyone have any thoughts?
regards
Flinze
sounds like a voltage regulator problem to me....
Hi
Thanks for the reply
is that voltage regulator as in part of the alternator?
Can I test this easily?
Flinze
no it's probably the one inside the instrumentation panel
Thanks for the info - can I test this?
It it repairable / replaceable?
Does this mean a whole new PCB?
Filnze
just change the whole unit... you do'nt need to fanny around with codes or anything.... see if you can get one from a breakers yard
ha. getting the dam instruments out is an art in it's self.
:iagree:
ha. you been there befor to.
I always end up breaking the plastic pegs on the base of the cluster, nothing a couple of cable ties can't sort out on re-assembly.
aye.. i have, i had the whole dashboard out becuase there was a problem with the wiring loom.... not a nice job:rolleyes:
Thanks for the advice - sounds like I am in for some fun:rolleyes:
I'll see if I can get a cluster from a breakers at reasonable cost.
Flinze
Posted in wrong one. sorry
get ya coat!!!
and some
My car has been visited by the Tachometer fairy :)
I've done nothing as yet and the last two days it has worked perfectly:confused:
Don't really know what to do now - I guess wait and see if it does it again.
Probably a poor solder joint or something similar I suppose.
Thanks for the input everyone.
regards
Flinze
  • 4 months later...
Did you have any luck fixing your rev counter? Mine does exactly the same thing but I don't want to take the dash apart if it didn't work!
In the event I did not need to fix it - it simply started behaving normally one day and has been fine since - no idea what was going on as I did nothing at all. :confused:
Sorry not much help.....
Flinze
