Temperature Gauge Sticking
Temperature Gauge was playing silly buggers this morning, I had driven about 4 - 5 miles (mostly uphill) and my temperature gauge needle was still at zero - Not having noticed this before, I keep a close eye on it, about a mile or so later as I started to decend the temp gauge (literally) sprang back into life then settled to normal temperature... :confused:
Anyone ever had this happen before? it was almost as if the needle was stuck.
Mine started doing this, I replaced the temperature sensor (about £25) and it's been fine since.
Seems to be a stock fault - it happened on my (previous) Octavia. A new temperature sender unit should do the trick.
happened on my vrs.Took snap connector off and cleaned connector is fine now.
