BIG exhaust needed......
HELP!!!
Can anyone point me in the right direction please........
I am looking at getting prices on a 3" stainless straight through cat-back exhaust system, can anyone recommend anywhere good?
Cheers:thumbup:
Miltek apparently do one. Awesome GTI seem to be a good place to start (I should get a discount on mine for this Sarah! :D )
Miltek do a 3" system then, I thought it was only 2.5"???:confused:
Yup. they used to do a 2.5" system and a 3" system. They now only do a 3" system. I know this as I'm getting one in the next few weeks (some research has been done :) )
Firstly, thank you for the info!!!!!!:thumbup:
Secondaly, how much?
I think this maybe what you're looking for...
"the downpipe is £316.00 + VAT and the system is £280.67 + VAT
Fitting on the downpipe and cat will be £90.00 + VAT"
For a custon job try www.primarydesighns.co.uk ask for Pat Barrett he made my 100cel downpipe and cat, badger Bill also uses him
HTH
Phil
Hayward and Scott.
"the downpipe is
3'' Blueflame down pipe and 100cel sports cat and a Jetex cat back exhaust is what I run... (see sig)
I need to replace part of the system, and wanted the biggest bore size as possible.
I had to get the back box changed as it cought my rear arb, and the nobs that changed the rear axle pipe/rear box only used 2"/2.25" stainless, Elton who is mapping the car this week now the IHI stuff is on says it may cause a restriction so my figures will be limited to 320-330bhp......
I figured if someone does a 3" system i'll replace the lot, and have the map tweeked at a later date when I have the pistons,rods etc. done.
The dp and sports cat are 3''...the cat back Jetex is 2.5''....runs 340bhp on max boost.
If you run a 3'' straight through..it will be very loud. Also I wonder whether you will need some back pressure....cat may gives this but I don't really all the in and out s of this.
H&S probably can do a custom job for you but...it will be expensive. Blueflame will more than likely would also be able to do a custom job.
Cheers for all of the advice guys:thumbup: :thumbup:
Hi
Have a look at JBS Designs in Chesterfield they have loads of experiance with big bhp Octy Mk1
Steve
Try Performance Exhaust Specialist - Blueflame
they will build you whatever you want & the prices are suprisingly good, Ive got one on my Octy with the IHI, 356 bhp with a bit of help from Jabba
HTH
Phil
they make wicked ****, but aren't they priced accordingly? a ceramic coated PD manifold for a FRS is like
If it is any help the black octavia that was here when you dropped yours off has also got a turbo kit, that is running a Pipe Werx 3" exhaust, that was made custom for the car as there isnt anyware ealse that does a FULL 3" system for the mk1 Octavia vRS, after seeing what a good job they done on that one we now send all our cars to him!!!! :)
