Inlet manifold
I've got a new inlet manifold to fit and when I do I also want to take the throttle body off and give it a clean.
When it all goes back together will I have to do a throttle body alignment with Vag-Com?
Or as long as I don't move/knock anything will it all be fine?
I was told to not move anything and it would be fine - it was :)
Thanks Phil :thumbup:
Looks like a job for Friday afternoon then, assuming my powder coated manifold turns up this week :D
Just something to note, any coating or polishing reduces the thermal qualities of the manifold and can raise intake temps.
i can understand how a coating can lower the manifolds ability to shed heat but if your coating with a material that vastly decreases the amount of heat the manifold absorbs from its surroundings, where its bolted to the engine and the air passing through it then surely its a good thing?
in theory that is :)
Hopefully won't be a problem for me.
I'm now running an FMIC and i'm going to fit the EVOshield gasket to reduce heat transfered to the inlet manifold from the block :)
Will post some pics when done.
What colour have you got then?
Was going to mention some sort of gasket to aid heat transfer.... i had a polished (externally) manifold on my old octy and a power gasket from Awesome... you could after a run out hold the inlet manifold !
I had problems when refitting the throttle body so i would say that it wont hurt to realign using vag-com if you have access and it isnt a major job for you.
In saying that mine started playing up shortly afterwards so the dealers changed it for a nice shiney new one under warranty... which was nice cause it looked better than the old one...
It's Satin Black and i'm having a number of the bolts chromed so should look rather nice when done. Will post pics.
Decided it was a cheaper option than your ABD manifold :rolleyes::thumbup:
One day gadget...:D
