Fabia vrs mods
Ive got two questions (1) Do octavia rs wheels fit on a fabia rs and what size tyres would need to be on them
(2) Can you fit a performance dump valve to a fabia rs?
1) apparently not, although Ross Clarke has put similar wheels from a Leon Cupra R on his, but I'm just as interested.
2) the Fabia uses a variable vane turbo insyead of a dump valve so the answer is no.
1) Again, I have heard that this is a no, but i would love to know exactly why as they both have 5x100 stud pattern. Perhaps the offset isn't enough to clear the brake calipers.
2) Most TDi's can have a dump valve fitted, but doesn't help outputs and in some cases actually decreases the power/torque figures!
1) Perhaps the offset isn't enough to clear the brake calipers.
This would be interesting........surely the Octy RS has bigger brakes than the Furby???
Also isn't the Furby's alloys just a 16'' version of the Octy's?
No they are a similar design, but different to the 16" Octavia wheels. If you look at them both together, the Fabia wheels look more chunky and thicker around the centre.
I recon the fabia wheels look better than the octiva wheels. The fabia just needs a 40mm drop and the wheels re doing in a anthracite colour ... yum.
The Octy wheels do fit the Fabia - I test drove a Yellow Fabia vRS at Wings in Peterborough - it had the very wheels fitted with 205/40/17 rubber :thumbup:
15mm will do as it is already 5mm lower than std, and your right about the anthracite.
Thought so, must decide between Octy wheels or Anthracite.
