Gas Struts
How would i know if my Struts are going or gone?
(the ones in the boot)
The boot lid would not stay up on its own.
and you might see an oily/greasy discharge where the rod comes out of the tube.
Yes you would know as the boot lid would drop on your head to remind you ;)
Not that expensive IIRC
Sarah
Thank you all.
When it is in the up position it stays there, but when you move it a bit it soon starts to drop.
Struts are softish then; new ones almost require you to step back so as to not get hit on the chin by the door going up! ;)
They should be just over £30 each.
We get them from the suppliers for about £5 each at work, for a similar sized unit. Sadly thought, they don't fit. Shows how much the dealer mark up is, as Skoda will pay a lot less then a fiver too.
Phil
