Octavia high clutch pedal
Hi my Octy 1.6 t plate has a high clutch and whilst I can live with it at the moment starting to find that I tend to have erratic gear changing due to the high clutch bit. The clutch doesn't slip attall just wondered If theres any way of adjusting the "bite" position on the pedal. Years ago a high clutch bite meant the clutch was on the way out but with self adjusting clutches I believe this is not the case...Any of you Skoda experts know of a cure Many thanks Chris
This is a problem why? (presuming the clutch isn't slipping)
About the only thing I can think of trying that might affect the biteing point would be to bleed the clutch.
The clutch is hydraulic if it is the same as on the TDI's which means it isn't adjustable.
