Oil temp sender pics needed.....
Sorry to bang on about this....:o
Has anyone got any pics or diagrams of where the oil temp sender goes....I know it locates in the blanking plug somewhere above or on the oil filter housing, but I can't see where:(
Cheers:thumbup:
Have you seen the diagram here ?
Marked as no. 10. Does that help or do you need me to attempt a photo? It's a bit tight inthere so can't promise a decent one.
It's a bit tight for getting the camera in there - this might help, might not.
14119.attach
Cheers for that Rob:thumbup: :thumbup: :thumbup:
Thats a massive help in what i'm trying to do!!!!!
Thanks again:thumbup: :thumbup:
Sorry to be a pain....again, but what part no. is the oil pressure switch on your diagram? Oil temp looks easy enough to do now I know where to look!
Cheers again:thumbup:
Glad that helped - as for oil pressure, sorry I don't know - I only fitted an oil temp gauge. 42 Draft Designs website (link above) is down - they have all the details on there - hopefully they will come back online.
I seem to recall you need an adapter to fit both oil temp and pressure senders.
You need an oil pressure relocation pack which ive got on mine.
Basically you unscrew the standard sender and put in adapter on a piece of pipe so that you can use two senders from one location.
If i remember ill show you a photo of mine
